Cam gurus inside
As for the square wave valve motion... that would be great if you didn't have inertia, both the physical parts and the air/fuel have inertia. You might also have a PV clearance problem banging the intake open near TDC of the intake stroke. Isn't it strange how all this stuff works together?
As for piston speed vs valve lift, acceleration means nothing, speed means nothing, pressure means everything. If you didn't open your intake valve until BDC at the very end of the intake stroke, you would have severe low pressure in that cylinder (1/10 of atmosphere even). If you opened the intake right then, the gas velocity would be like nothing you'd ever seen. It would also be too short of an intake cycle to be worth anything. "Area under the curve" can make your brain hurt.
gas volume = gas speed * time
gas speed =? pressure difference / restrictions / inertia of air * a whole bunch of other crap that all changes contantly over time, while trying not to break your valvetrain off.
Please, someone post a spreadsheet.
assuming conservation of mass
Bret
