Cam gurus inside
I understand that a wilder engine will need different profiles, and I'm not planning to see anything faster than mid-11s(don't want to hack the car up to put in a cage), so let's look at this as a stock-cube NA engine that might see 6500-6800 rpm max. Thanks a ton for y'all's input.
You want the valve to have its greatest point of valve lift at the greast point of acceleration of the piston. This will lead to the strongest vaccum signal to fill the cylinder. In most engines this occurs around 75 ATDC. But, you can play with one of those neat plots to see where this takes place, and shoot for that. It has to do with rod length, bore, etc...
Its just one of the things that folks ignore when they stick to the "Everything has to be 112 or 114 +4" argument
But still, the first thing when choosing a cam is the IVC. This determines how much A/F mixture you are going to be able to trap.
If anyone has any questions where there peak speeds of the engine are at, send me a message. I have put together an Excel spreadsheet that calculates all of this for me. Just need some basic info.
Am I in the ballpark of a good choice???
So if the air has inertia because it has mass, how do you get it to follow the piston velocity over a broad range of rpm, say 2000-6000? IOW, the slug (pun intended) of injested air isn't attached to the piston with a "cable" but rather a "rubber band". To my mind that makes the real world optimum valve lift profile less simple than you stated.
My $.02
The cylinder heads are only ONE part of the situation on what the camshaft specs are based around. 100% of the time the more you open up the valve the more the heads flow, but if the flow doesn't increase the more you open the valve there still is good reason to open the valve even more.
The max valve lift of the cam is dependant on the valvesprings, but if you don't have limits in that situation then it's based on the valve size, engine RPM and displacement.
As for the pressure differentials that's the camp I'm in. There are the piston velocity determines the cylinder filling guys, but that doesn't explain all of what's going on in cylinder filling.
Ric,
Bret
Since everything takes time, you need to open the intake valve btdc to get the charge moving by the inertia that the exhaust has on the chamber, ie overlap.
Once everything is going, you want a cam that opens very aggressivley from 0 to 75 deg of piston motion, with peak lift occuring at 75 degrees. You also would want your peak lift to be beyond peak flow of the cylinder head because like I said before things take time, so you could hit the peak flow of your cylinder head twice instead of once.
Then, you have to think about how much ramming effect you are going to get from the inertia of the incoming charge. You want to close the valve soon enough to trap the best overall charge. This is obviously dependant on RPM because the inertia of the incoming charge rises with RPM. So, you would want to close the intake valve sooner down low and progressively retard it towards torque peak, and then, after torque peak you want to start closing it sooner again because VE is going down.
Oh man, I could go on for days about this stuff.
I'm not convinced you understand everything you know about this. No offense intended.
As the piston begins accelerating away from TDC, the exhaust valve continues to close, preventing too much of our fresh air and fuel from leaving the chamber. Meanwhile the piston begins accelerating our column of air into the cylinder, as the valve lifts farther off the seat and flow potential continues to rise.
Now lets say that your mild heads flow 290 cfm at .550 lift, but the port doesn't introduce undue turbulence or stack up air at higher lifts up to 600. If you can still flow 280 cfm into the port up to .600 lift, inertia is going to continue filling at a faster rate, even though the flow sheet says its past its max.
Others have already established where we want the valve to close, and I'm sure they could do a better job than I explaining why. But it seemed from the explanation you had given that you are leaving a lot on the table, before we got to the closing point.
There are a lot of people here who know far more than I do, so if I'm missing something here, please chime in.
The above thread may answer many questions for you guys. Like said previously I asked this quite a while ago regarding my combination. My ports don't pick up flow from .600 to .700 but my cam lift is .754, hmmmm, wonder why
LOW LIFT FLOW....
The reason it's not as important is due to the pressures difference between the port and the cylinder when the valve is at these lifts. You can easily see a 200" of H2O depression difference or more at these lifts. A change in 10cfm @ .100" is pretty large in terms of percentage of how much the port flows at .100" but the motors demand on the port is more than taken care of at depressions that large even with the lower flow @ 28". Say if your port flows 70cfm @ 28" when the valve is at .100" lift. At the higher depression of 200" the port can easily flow 200cfm but the demand is not that high.
Bret
A perfect world would have a valve open instantly and close instantly at certain points. Since that would break the valvetrain at high RPM, the valves are opened gradually. This is called ramp rate. High ramp rate cams are noisier, break sooner, and can't be spun as quickly (assuming everything else is equal), but they do flow more. Since, you can't open your valve instantly, you can get more "area under the curve" on your flow by opening a little early. Doing this too soon will get blowback, but in small doses it works because: 1. the piston is barely moving, so there is little pressure (comparitively) and 2. the valve is barely open at this point. This way, when the piston starts sucking more air, the valve is open a little already.
I'm told that opening intake early when the exhaust is still open can help scavenging by letting clean air help push exhaust gases out and letting the scavenging effect fill your cylinder with clean air slightly. I've heard that you can shoot some unburnt fuel into your exhaust this way. Maybe there is a way around that?
That's about all I "know" about it. I won't be hurt if someone wants to disagree.
The point of this thread is that there are hundereds of variables that you would have to take into consideration to design the 'perfect' camshaft. And that 'perfect' camshaft would only be perfect for setups identical to yours. This kind of research would take resources that most of your average joes (like me) dont have.
would not necessarily be best for an ET of eleven seconds. SCR has a big
impact on IVC.
helps get the waste out, and the new charge into the cylinder.
According to Vizard, the exhaust gasses in the correct tuned RPM range can
begin filling the cylinder even before the piston creates a depression.
As the exhaust gasses leave, there is a low pressure area created which begins
to pull in the intake charge. The greater the pressure differential, coupled
with correct valve timing and pulse arrival at the respective ports will increase
VE substantially.
Reading further up, J-Rod touched on optimal ICL. Would ICL occur at max
piston velocity, or a little later? I would think the air is lagging the piston,
therefore ICL would happen a touch after max piston velocity?
