Detailed Cam Spec Determination ?'s
When someone has determined what heads they're using, range of durations (RPM Range) they want to stay in and what types of lobes they want to use or can deal with, whats next?
What calculations in the spreadsheet should one be looking at to optimize the set up?
For example -> get the DCR close to 8.5 as possible
What about VE's? - which ones provide good driveability, which ones provide the power?
What about overlap? What does that affect
Can one determine if a cam will fit or not based on the spreadsheet?
or what makes one cam fit and another not fit even though the durations or lift is smaller?
Hope this will answer some questions not only that I have but others too.
One of the best engine guys I've ever heard of heard of wants to be cremated when he dies, have his ashes mixed into 55 gallons of race gas, and run the gas thru a race engine at full grunt so he can actually see what's happening in the engine!
While he's still alive and kicking he's measuring a whole bunch of stuff going on inside race engines, and then trying to explain what he measures. He is a Phd. and works for a Cup team. Some of what he's found is surprising.My point is that a spreadsheet isn't going to do much to help you optimize a cam for a particular combination. Knowing how an engine works, what has worked or not worked in the past, and a little out of the box thinking is probably a more successful approach. Lots of testing helps too!
While I think it's neat idea to be able to spec you own cam, I'd ask a specialist before I'd spend my money. I'd do the same thing if I were sick and needed medical attention.
My $.02.
My $.02.
If you have two cams (that have been known to work) to throw into the spreadsheet, how do you tell if one is better for you than the other(based on your desired result)?
Engines don't read spreadsheets.
and this cam will NOT fit: 224/228 578/578 112 per the same vendor
Both cams are sold by this vendor. However this is all the information I have on these two cams. I don't know what types of lobes they are.
I want a cam that will be a fun on the street cam only and then work well with a good set of heads.
Those cams are both really small for not fitting so i'm guessing you have a big valve in there and a lot of milling on the heads.
Bret
Bret
Maybe you can help all of us out by telling us what you are trying to do with your car? It seems this post is more about you choosing between two cams so you can find whats right for you.
rick
As mentionned above, experience and motor dynamics understanding play the major role.
Still understanding how VEs work will give a good image of the power range of said cam.
We are now going on our 10th year dealing with LS motors and one can see how cam theologies are evolving. Just in the recent months, we are starting to see members paying interest to VE's, SCR and DCR instead of just "this is the biggest I can fit, so it will make more power".
Missmatched parts are the biggest dissapointment in actual modding. So the trick is to match parts properly and not just shove the biggest part in there a expect ultimate power.
