compression test question
Rick
That I know, so if I have more overlap on the seat timing then I will have less cranking correct?
Or does only IVC effect cranking?
Rick
Example: We tested a 13:1 CR 358" Chev with a mechanical roller 300/311° cam (~270/280 @ 0.050") with a 114° LCA cam 'straight up' (no advance or retard). The cranking compression was only 130 psi. We then tried a 300/306° cam with 107° LCA 2° advanced (~12° more overlap, but the relevant feature being a 9° earlier IVC) and the compression went up to 180 psi.
(BTW, the first cam made 735 HP @ 7,900 RPM, with ~505 -510 lb-ft. of torque from 6,000 to 7,000. The second was down 30 HP but made 12 more lb-ft over a narrower band and had almost the same average power from 6,000 to 8,000.)
Rick
