What are the advantages/disadvantages of longer connecting rods?
#63
Originally Posted by Old SStroker
FWIW(2):
If you look at peak intake port velocity vs. peak piston velocity, say in a Pro Stock @ 10000, the peak intake port velocity is more than 3 times the maximum piston velocity. 9795 ft/min or ~163 ft/sec. piston velocity, and about 500-540 ft/sec. port velocity.
That's where we run into problems. The longer the rod, the lower the max port velocity with the same port.
#65
Originally Posted by CamKing
Max port velocity in the cup engines is reaching 600ft/sec.
#66
FWIW, some mean (average) piston speeds and R/S ratios:
F1 @ 20000 rpm: ~5200 Ft/min, R/S about 2.0+:1
Cup @ 9700 rpm: ~ 5200 Ft/min, R/S about 1.90:1 (6.2/3.26)
ProStock @10000 rpm: ~6000 ft/min, R/S about 1.70:1 (6.125/3.60)
LS7 production engine @7000 rpm: ~4600 ft/min, R/S about 1.52:1 (6.066/4.0)
FWIW(2):
FWIW(2):
They (IHRA PS), make peak power at 6600-6900 FPM mean piston speed with a 1.35-ish to 1 R/S ratio and turn up to 7500 FPM max piston speed which is what you are listing up there.
Their stroke is nearly 6 inches or about 5.7 inches on average so their rpm is almost the same as their piston speed in FPM!
Since they turn much lower rpm they can run quite a bit crazier cam profiles of course which allows the same heads to breath at higher pistons speeds than if this same piston speed was gained with RPM.
Kind of gives you a pretty good window into what is limiting airflow more in these super high rpm engines, valvetrain or ports!
#67
Are you sure?
What's the barometric pressure and temp in the port?
#68
Are you sure?
Often the charge temp in NA inlet runners is less than ambient, especially after the fuel is added.
600 fps is near M 0.55 which seems to be where flow gets into trouble in an engine's inlet ports.
#71
When looking at rod length, you have to look at it as Rod/stroke ratio.
When running a given size stroke there is an advantage to running a longer rod.
an engine with a rod/stroke ratio of 2:1 will have a slower max piston speed at the same RPM as an engine with a rod/stroke ratio of 1.7:1.
This will effect top end power by allowing the engine to turn more RPM before the piston velocity causes choke flow. This isn't a big deal on the average engine, but it's a big deal on engines that run piston speeds in the 4,500 average feet per minute range. After about a 2:1 rod/stroke ratio the gains become very small.
The disadvantage of the longer rod is that at low rpm's the lower max piston speed dousn't have as strong of a pull on the intake port and will decrease the power at low rpm's. I normally have to put a 4-degree shorter cam in these applications to get the torque back up, and the longer rod will carry the power as if it had the bigger cam in.
Choked flow is a limiting condition which, if the flowing fluid is a gas, occurs when the gas velocity traveling through the restriction increases to the speed of sound in the gas. At that point, the gas velocity becomes independent of the downstream environment pressure (i.e, lowering the downstream pressure will not increase the gas velocity any further).
#72
Pressure has no effect on the Speed of Sound; only temperature.
When you add fuel, things change. The density and the pressure no longer cancel each other out.
The air is elastic, the fuel is not.
κ is the adiabatic index also known as the isentropic expansion factor and sometimes called γ (Greek letter gamma). It is the ratio of constant-pressure to constant-volume heat capacities of the gas (Cp / Cv), and arises because a classical sound wave induces an adiabatic compression, in which the heat of the compression does not have enough time to escape the pressure pulse, and thus contributes to the pressure induced by the compression.
p is the pressure.
#75
Only in an ideal gas like air.
The range of gamma for this still seems to be in the range of 1.3-1.4,
which should be less than 5%.
#76
Originally Posted by DavidNJ
Do you have a reference to an article about the speed of sound in a gas with a liquid in solution?
A friend of mine that helps me in this area is a lead engineer on the Scramjet project.
We were just talking about how the pressure differentials of both sides of an orifice change the choke flow of the orifice.
#77
Camking, I know you are in the business for real so I know you already know the answer to this question but I will ask it to you anyway since on this board and others there is sometimes still some argument about it at times.
What I am saying is that valvetrain is what is limiting 99 percent of the super high RPM pushrod engines such as Cup or PS right now. It limits reliability, it limits power and it limits airflow. Right now we have heads in PS and Cup that are not even run although they are bigger and better but the valvetrain and valve sizes and mass right now limit us in RPM more than the heads and their airflow do. The cam and valvetrain are now more important than anything else in the quest for more power through RPM.
You could lame out the lift and intensity of the cam but then power will fall even as rpm rises which means you are slower. If you run larger duration tamer lobes you start inceasing overlap and bleeding off compression on intake closing too. You also will increase reversion so again you will lose power by simply running longer durations with lower lift if you are trying to make good VE. Anyone can turn more rpm by running a lower lift cam with a lot tamer lobe and 600 PSI seat pressure and turn rpm to the moon but the power will plummet whether you are turning more rpm or not because the airflow has too.
You could run bigger heads with bigger ports but that means bigger valves as well which are heavier and must be opened further so again the cam must be appropriately more intense at the same rpm to get this bigger valve open and open further as well if you want to fully utilize these new heads and really make more power. The problem though is as valves get bigger they also get heavier. This means that if you were already on the edge of valvetrain control you will now lose valvetrain control at a lower rpm due to the newer but larger and also higher mass intake valve.
So at some point you are stuck at how big a head to run VS. how radical you can keep the cam and the valvetrain and hold it all together. It's basically a compromise between all these things. Almost anything you do to make more power through rpm also limits your RPM. This is why there is always a limit to the rpm that these engines seem to turn and make good power at. Right now the valvetrain is where that limit is at.
#78
Erik, I thought we were focused on the affects of rod/stroke ratio on flow, rather than valvetrain or porting.
This section of the thread really got started when CamKing indicated that the rod/stroke ratio has an affect that is compenstated for with valve timing. Specifically, that the (slightly) higher peak piston speeds from a lower rod/stroke ratio could cause choked flow in high rpm engines. That a higher rod/stroke ratio reduced this at the expense of lower end torque. And that a reduction in IVC compenstated for that.
This led to a discussion of whether the intake port or curtain area had sonic flow, a requirement for choked flow.
Are you saying the choked flow is past the valve at low lift? The peak piston speed occurs close to peak valve lift.
#79
David,
The problem is we can agree here on how the world works.... We are talking about pressure here, but everyone seems to think that velocity of the port is directly linked to the velocity of the piston. The pressure differential between the port and the cylinder is what matters, but everyone thinks that air/fuel is some magical string that's attached to the top of the piston and when the piston goes faster so does the air/fuel charge. Everything has inertia and the higher you spin the motor the bigger gap between peak piston velocity and peak port velocity.... I think Adrenaline Z entered this "Is this a good time to discuss flow separation?" at the right time in the discussion since the flow separation of air and fuel is one of the many things that causes the limiting port velocity of most ports. Things are just going too fast for the fuel to make the turn with the air. This is considered the choke point of the motor... you can cause this to happen with a lot of changes to the system, the rod length (not rod stroke ratio) might have enough impact on this IF you have a perfectly matched system to start with. For what we are talking about most times that's far from whats going on.
Eric,
There is some odd ball thing that is happening at very high piston speeds 5500ft/sec+ but the answers I have heard about that are more akin to walking in the house, seeing a pile of dog **** on the carpet and then yelling at one of the many dogs and sending him outside. Obviously it was one of the dogs that put the pile there but I think that they are yelling at the wrong dog. If I had a answer for this that I thought was satisfactory I would go with it, but I don't and from what I have seen nobody else does either. We are here to explain how the world works not tell it how it works, mother nature don't care what we have to say.
As for the RPM limit, I think you hit the nail on the head more here than most times.... IT'S EVERYTHING! Once you change one part of a motor, everything else changes. If you are not pushing everything to the limit you are not doing it right and that's what we have been "discussing" between us for years now. I think we can agree it's not just one thing that limits these motors we discuss.
That's why this rod length question is retarded.... how can anyone say that just the rod length change in a motor is causing something to happen? What else did you have to change to get the new rod in the motor? The piston, the ring pack, the deck height, now add on all the other things that have to change with every one of those changes.... maybe a different shaped piston skirt design, maybe a different gas port arrangement or different scavenging system. If you changed the deck height you would have so many variables in your hands it would be crazy. Nothing is a stand alone specification in the motor. So these discussions are retarded, and nobody knows the real answer. Maybe one combination worked better than another but to pin point it to something like rod length is crazy... yeah theoretically it can cause certain things relative to port size etc... but by it self rod lengths effect on power is minimal. That is by far not even the sratching of the surface on this topic.
Camking,
First off, ya gotta start writing for the masses a little better. When the people on here who are smart enough to understand this take a few times of reading it to understand it, you don't have a clue who you are really writing for on here.
"κ is the adiabatic index also known as the isentropic expansion factor and sometimes called γ (Greek letter gamma). It is the ratio of constant-pressure to constant-volume heat capacities of the gas (Cp / Cv), and arises because a classical sound wave induces an adiabatic compression, in which the heat of the compression does not have enough time to escape the pressure pulse, and thus contributes to the pressure induced by the compression. p is the pressure."
FWIW, were are not concerned with a sound wave causing adiabatic compression, it's a pressure wave, but for some reason you keep talking about the pressure and not the sound wave. So obviously you get it, but it's kind of like talking in different tenses in the same sentence.
Maybe using a link would work that much better... http://en.wikipedia.org/wiki/Adiabatic_index
Anyways... this idea of the speed of sound and the pressure wave I think are all getting confused here. The pressure wave is not moving at the speed of sound ( I could be wrong here ), and the air/fuel certainly isin't. The theory that the pressure waves compression of the charge increases the temp because the volume can't change and react seems off to me. The volume of charge can move so the temp change doesn't happen as much, it's more likely that the pressure increases. IF the temp does increase then after it enters the cylinder and expands it should cool off so it's basically null.
Bret
Eric,
Camking,
Bret
#80
Originally Posted by SStrokerAce
Camking,
It has been proven over and over again that the rod/stroke ratio effects the performance of the engine, and that a 2:1 rod to stroke ratio is the most efficient for an engine turning over 4,500 ft/min piston speed.
If you take 2 engines where everything is the same except the rod length and the pin height, the longer rod engine will lose a little torque, gain a little HP, and hold the power for more RPM's.
If you take two 355ci SB Chevy's, one with a 5.7 rod, and one with a 6.125 rod. The one with the 6.125 rod can run a 4 degree shorter cam on a 2 degree tighter lobe center and still make more HP, and carry it further.
Remember, air is elastic and it flows toward the lowest pressure point. Changing the rod/stroke ratio changes the pressures in the cyl.
A shorter rod/stroke reaches max piston speed in fewer degrees then a longer rod/stroke does. A 2:1 rod/stroke ratio reaches max piston speed close to 90 from TDC. This causes a more even pull on the intake.
