Advanced Engineering Tech For the more hardcore LS1TECH residents
diffrence between??
Old Jun 5, 2006 | 10:23 AM
rgaynor85's Avatar
Question diffrence between??
ok what is the diffrence between flat plane crank and a dual plane crank. friend of mine asked me and im not sure. i dont think it has anyting to do with lsx's but it might i dunno lemme know thanks
Ryan
Old Jun 5, 2006 | 10:36 AM
Adrenaline_Z's Avatar
Could you possibly be talking about 90 degree crank (dual plane) and a 180 degree crank (single plane)?
When looking from the front of the crank shaft, the crank arms of a 90 degree
crank will make a '+' symbol, whereas a 180 degree crank forms a line " I "
Old Jun 5, 2006 | 10:41 AM
rgaynor85's Avatar
im not sure he was reading about a new BMW M3 v8 comin out and he just asked me whats the diffrence bewtween a flat plane and a dual plane and i had no clue so i figured id ask on here sense a ton of u guy r smart as hell.
Old Jun 5, 2006 | 10:46 AM
Check out this article, about mid-way down the page on the right side, you
will see a diagram of 3 crankshaft types:
http://www.mustangandfords.com/howto/29178/
Old Jun 5, 2006 | 10:49 AM
rgaynor85's Avatar
yup that explains it i think il read that aritcle now thanks
Old Jun 5, 2006 | 11:12 AM
Old SStroker's Avatar
A 180° crank, "single plane" or "flat" crank treats a V8 like two 4 cylinder engines as far as exhaust tuning is concerned because all the cylinders on a bank fire at even intervals of 180°. They also vibrate a lot more than 90° "two plane" cranks we normally use.
Two common uses in racing are 2006 F1 V8s and IRL V8s. The have a districtive sound when unmuffled.
Old Jun 5, 2006 | 02:08 PM
Anonymous's Avatar
10 second playa
What is the advantage to using the flat crank?
Old Jun 5, 2006 | 02:52 PM
rgaynor85's Avatar
i think the flat ones are better balanced and can rev higher
Old Jun 5, 2006 | 03:15 PM
A 180° crank, "single plane" or "flat" crank treats a V8 like two 4 cylinder (edit: INLINE) engines as far as exhaust tuning is concerned because all the cylinders on a bank fire at even intervals of 180°. They also vibrate a lot more than 90° "two plane" cranks we normally use.
You can get better exhaust scavenging and intake tuning if all cylinders on one bank fire 180° apart like an inline 4 rather than 270°, 180° and 90° apart like with a 2-plane crank V8.
To get 180° exhaust pulses in 4>1 headers on 2-plane V8s you need to use crossover primaries. If this isn't allowed or practical from a packaging viewpoint, the flat crank V8 can usually be tuned to produce slightly more power inspite of more severe vibrations than a 2-plane.
Revability should not be different.
FWIW, the V10 F1 engines of the recent past were built on various bank angles like 72°, 90°, 106°/108° and some others. For exhaust tuning they were treated like 2 inline five cylinder engines.
Old Jun 7, 2006 | 04:33 PM
Anonymous's Avatar
10 second playa
Interesting. Thanks.
