Advanced Engineering Tech For the more hardcore LS1TECH residents
air distribution
Old Jun 5, 2006 | 05:25 PM
Rusted40's Avatar
Default air distribution
seems I'm having a low speed air distribution problem
my setup is a single plane intake with an elbow and 105mm TB
EGT's even out more at RPM's but 6&8 cylinders run hot(1450>1350)
I've switched injectors around with same results
I know SBC and LSX are different animals, but maybe
some of you have had similar results?
homepage
Old Jun 8, 2006 | 04:46 PM
under pressure's Avatar
Is any of this due to the SBC firing order and the location of the 6 and 8 intake valves next to each other? By the way, I sure like your project. Very cool.
Old Jun 8, 2006 | 10:44 PM
Rusted40's Avatar
thanks for the reply
it turned out to be a common problem associated with the elbow
I made a thin spacer with part of it protruding into the plenum
this deflects the flow towards the center of the plenum instead
of scooting down the back of it
took me a couple of hours and probably saved my rear cylinders
