If you have an engine that is compression limited(low) can you still make good power?
Ok, so the main question is, can a cam be designed to work with low compression and still make good power?
Here will be my specific combo;
Compression will be about 9.5 to one.
The combo is a 402 iron block with -14cc dish , pistons out of the hole .008, AFR 225’s w/72cc chambers with either a .045 or .040 gasket. Pick one, for whatever the best quench #.
This will eventually be a moderate boost engine. But, for the NA break in period, this is what the rest of the combo will be …
Fast 90
NW TB.
ASP Pulley
EWP
42lbs injectors
QTP two piece timing cover
QTP high volume oil pump
QTP 1 7/8ths HVMC thru their 3’ Y and out thru a Magnaflow cat back.
Fast 90
NW TB.
ASP Pulley
EWP
42lbs injectors
If you get a cam with a really advanced intake lobe, you will be able to recover some of the torque loss down low by raising the DCR. I would recommend the Katech Torquer cam as this will be a good cam for the future supercharger and it will have great response because of the early IVC point.
Play around with J-Rod's quick and dirty spreadsheet. You'll want to play around with the cam timing to keep the IVC around 48-50 degrees ABDC at .050" (for a 402) and boost your DCR up to 8.5:1 (if possible). To do this, you'll most likely be running a pretty narrow LSA cam. Should be fun.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
