Advanced Engineering Tech For the more hardcore LS1TECH residents
What's the ideal DCR for LSx Engines
Old Jul 2, 2006 | 11:53 AM
DavidNJ's Avatar
Originally Posted by gun5l1ng3r
And a valve adjustment thing (every 10K mi?)...
Yes...valve adjustment has to be done every now and then. Which is why it is an emissions thing. I would hope you are checking things over every 10-15k miles in your 450rwhp, 520fwhp, 5.7L, 91 hp/liter engine!
In the 60s and 70s, no real high performance engine came with hydraulic lifters. My Supra TT doesn't have them either. And I believe people take them out of DOHC modular Fords also.
Old Jul 2, 2006 | 11:57 AM
1989GTA's Avatar
Thanks for posting the article. Excellant read. Vizard states if you do what he says you can run a 1/2 point higher than what the chart says. Also he does not differentiate between aluminum and iron heads. Thought that was odd.
Old Jul 4, 2006 | 07:19 AM
Viper's Avatar
He does mention aluminum heads halfway through.
Old Jul 10, 2006 | 08:33 PM
LIL SS's Avatar
Moderator
So ok.. Detonation is caused by a lot of things right? To high of a DCR with not enough octane at a high temp is one of them right. Well, what would be better for bottom end torque and shifting at say 6200-6300rpm:
Motor details:
348ci
-2cc forged pistons
Stock heads
Z06 manifolds
Lower DCR (8.0ish) running 91 octane at 180* with higher timing
or
Higher DCR (8.5ish) running 91 octane at 175* with less timing
Old Jul 11, 2006 | 04:35 PM
racecar's Avatar
I can tell you that 9.3 DCR knocks pretty bad on pump gas. Even with the .040 gasket. Knock is a killer on race engines.
Old Jul 12, 2006 | 12:51 PM
SStrokerAce's Avatar
For me the most DCR I can run with the coolest temps and NOT dialing back timing is a winner.
Bret
