Cam shaft selection with N20 use in mind (CamKing , racer7088 etc...)
#41
Originally Posted by Adrenaline_Z
Ha, love it. Sort of reminds me of a discussion I had back in the day on this
forum about Nitrous and relatively low compression.
Nice to know someone knows better!
#42
I'm a firm believer in letting the engine breathe and let the valve timing
fill the cylinder as opposed to raising the SCR to make up the difference.
There is more power available from more charge entering, than a smaller charge
which is compressed higher.
Fuel type is always a concern when selecting the variables, so I wouldn't
know how to answer in a general view.
Selecting your maximum SCR without knowing how well the engine breathes
and target DCR for a specific fuel is a shot in the dark. Even knowing those
variables is still a science.
I would be looking at the torque peak RPM and work from there.
#43
Originally Posted by racer7088
Yes it is but I am encouraged that people are at least talking about all this stuff. The problem is that there are still guys telling people like Friendly Freddie that you can increase overlap and "bleed off compression!" This is the stuff that scares me and I hear stuff like that everday. People should know better. Even with all the cam talk on these boards though I just never stop hearing the crap like that.
Freedie,
I would say the 13-14 range would be much better than 15.5:1. I think you can tune the compression with a new cylinder head with a larger chamber and settle most of your issues. You might also want to try different gasket thicknesses, maybe even larger than what you are running right now, and not just to control the compression ratio.
Bret
#44
With my given situation I feel like I should get these AFR castings that I already own, finished up. If I don't make any more power than I have now, at least the thicker deck and better casting quality should bring me some reliability(and bring compression down a touch). Have my cam reground (or buy a new one) , this should net me a HP gain.
#45
I am limited by a small bore (4.030), and the fact that the engine is only 358ci. The cylinder heads flow mid 330's at 600 lift.
Seems to me you might have too much head for the displacement. What RPM are
you spinning to? What size are the ports?
THe cam specs that you have listed seem fairly decent. I would imagine the
overlap region is fairly high on a 110 LSA? Do you have the valve timing?
As for breathing, if you're limited with bore diameter, there's always power to
be found in the intake and exhaust lengths. What sort of exhaust setup
are you using, and what are the details?
Keep in mind, this reply is based on 69.9% theory, 20% application and, 10% dyno testing...the other .1% contains a little luck and bench racing! ha
#46
8 Sec Tuner
Originally Posted by Friendly Freddie
In this app I kinda have a problem with "breathing" so to speak. I am limited by a small bore (4.030), and the fact that the engine is only 358ci. The cylinder heads flow mid 330's at 600 lift. If I go to a cylinder head like an ETP 4.0 bore LS7 (because it flows better than my existing head) will I have to spin the engine even higher to make use of the extra intake capacity? I am already buzzing this little engine to it's limit. The gearing , and converter already work very well with the power band I have now. I have never had the engine on a dyno , so I could'nt honestly tell you where it truely makes peak torque. Chassis dyno torque #s don't mean squat with a really large converter.
#47
Talk about intimidation...posting behind Bret and Erik!
I have had the car on the limiter on a couple of occasions
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
The long and short of it is this, I have to do some work to get the info everybody is asking me about.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#48
Originally Posted by Mike TexaSS
Ditch whatever crankshaft you have and get a bigger one.
#49
9100 RPM is not for the average valvetrain or cylinder head. I was under the
impression this was more a street/strip motor than a pure strip motor.
I bet the placement of that muffler will pick up some power. Is the muffler
connected dirrectly to the collector? Have you tried extending the collector
before inserting the muffler? Collector design, length and secondary length is very important.
I run a 1 7/8" stepped to 2" with 3 1/2" collector Kooks header , with a header muffler and then a short section of pipe with turn downs.
#50
heres a clip of the car.
http://video.ls1tech.com/search/8.73...72E1CACD51.htm
#52
I have about 4 or 5 inches of pipe between the muffler and the collector and then maybe 24" after the muffler before I put the turn downs in place. What is the proper procedure for calculating these lengths?
Sean,
What ive always used for the folks that want header/muffler setups is the ole crayon trick. When the wax stops melting, i place the muffler there and then a short turndown at the end. It really depends on how well your collectors scavense as well. Poor collectors seem to lose exhaust velocity shorter and quicker compared the to the better versions. When tuning the headers on the Edelbrocks I shoot for around 32" total primary lenght before adding the collector (HVMC's at the end). Seems to be working on the cars ive used them on for making good all around power.
Mike
#54
Originally Posted by Ben R
Are you using a 5.3L crankshaft to make a 358 with a 4.030" bore?
#55
Static compression doesnt work for much on a heavy nitrous motor. 15 hp doesnt go far when 50 is just another jet away.
Weve got cars going fast on 10.8 that was originally setup for 11.5
I always would err on the lower side for compression than higher - as per Erik and a few others that know well. Big nitrous motors are like Fuel motors than anything else in my opinion
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#56
#58
Pm me, up the pimpness on the plate you can run more nitrous accurately through a plate system than an LS1 will keep its heads down on under any circumstances
#59
The crayon/paint method is much better than guessing, but according to
several tuners, the length is not optimum.
Where the exhaust heat stops burning off the paint, or crayon does not
necessarily represent the tuned wave length for a specific RPM.
I don't know of any programs that calculate the correct length.
Does "Pipemax" have such a feature?
I have used some empirical values suggested by Vizard to tune my exhaust.
#60
I just need the seat duration of the exhaust lobe(not .020" duration, but the actual opening to closing points.), the RPM that you want tho length tuned for, and the exhaust temp at that RPM.
