Advanced Engineering Tech For the more hardcore LS1TECH residents
Header length and size calculator
Old Aug 15, 2006 | 09:57 AM
Phil99vette's Avatar
7 Second Club
Default Header length and size calculator
Anyone have a decent program that will calculate header primary size and length?
Old Aug 15, 2006 | 10:27 AM
Ed Wright's Avatar
9-Second Club
You can buy Pipemax software here: http://www.maxracesoftware.com/
This is what everybody I know uses. Very good, reasonable price.
Old Aug 15, 2006 | 03:55 PM
Pecos Pete's Avatar
Default Here is a no cost one
http://www.headerdesign.com/login/header.asp
BTW, still loving my Fastchips PCM. It's on a 1997 Yukon you did for me a few years back.
Can you tune for E85 only?
https://ls1tech.com/forums/generation-iii-internal-engine/557583-lsx-motor-built-e85.html
Old Aug 17, 2006 | 08:38 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Its in my spreadsheet for Valve events.
You can put in your motor specs, and look down the page and it give you header length and primary size.
The formulas I have are:
Header pipe length (in inches) = ((850*(360-EVO))/RPM – 3
Header diameter (in inches) = ((cylinder. disp. * 16.38 / ((hdr len + 3) * 25))) * 2.1
EVO - Exhaust Valve Opens (gross)
These formulas are from A. Graham Bell’s Performance Tuning in Theory and Practice.
For a street engine, the RPM used should be the peak torque RPM. For a race engine, the peak hp RPM should be used. I find that the peak tq numers to be insanely long. So, I use peak HP.
Old Aug 17, 2006 | 12:21 PM
SStrokerAce's Avatar
Just use pipemax
Old Aug 17, 2006 | 08:20 PM
Ed Wright's Avatar
9-Second Club
https://ls1tech.com/forums/showthread.php?t=557583
Great! Glad you like it. Guess I'm going to have to work on that. I haven't seen it around here yet. Your not the first to ask about that. If I can locate a source here, I'll look into tuning for it.
Take care, Ed
Old Aug 18, 2006 | 04:05 PM
ringram's Avatar
There is a good article by David Vizard here
http://www.popularhotrodding.com/eng...exh/index.html
Plus a good quick size table here http://www.popularhotrodding.com/eng.../photo_04.html
Old Aug 19, 2006 | 10:03 AM
TRW427SS's Avatar
Yes, the headers built by Futral Motorsports for their 854hp 427ci C5R engine were built using Pipemax!!
