Advanced Engineering Tech For the more hardcore LS1TECH residents
Possible to create variable runner length/diameter based on rpm?
Old Oct 17, 2006 | 02:00 AM
FieroZ34's Avatar
Weird. Looking at that pic, the injectors are placed very low, which is not an advantage. Some sportbikes have dual stage, with the lower RPM injectors low like on the R1 above, but have secondaries for the higher RPM, which are larger and placed up on the velocity stacks.
Here is a 3D image from TWM Induction for a Porsche 6cyl:
Old Oct 17, 2006 | 08:13 AM
MrDude_1's Avatar
Originally Posted by FieroZ34
This doesn't surprise me, motorcycle engine technology is always behind automobiles (Again, space, weight, and cost).
umm, for production vehicle VS production vechile?
if so, you're sorely mistaken, or just looking at the wrong models... you probably didn't look that deeply into it before you said that.
Old Oct 17, 2006 | 09:18 AM
FieroZ34's Avatar
Motorcycles have always been advanced if you consider DOHC 4v/cyl technology, but I don't. That's pretty much commonplace now.
However, when did sportbikes all have fuel injection? Even in the late 90s the Yamahas were still carb'd. It isn't that they are behind because of lack of innovation, they are just behind because it isn't practical. It's odd, in some aspects they are far more advanced than any car has been (Cylinder head design for example), but in other areas they are still far behind (Variable cam phasing, variable/staged runner lengths, etc).
