Advanced Engineering Tech For the more hardcore LS1TECH residents
solenoid valve timing
Old Sep 5, 2006 | 07:56 AM
ProdriveMS's Avatar
There is still a cam. The rocker pivot can move which is what varies duration and lift. The engine actually has no throttle butterfly. Throttling can now take place through valve lift and timing.
Al
Old Sep 5, 2006 | 09:26 PM
rubin's Avatar
Al
thats what i read about the vandos system but this engine has ITB. thats why i wasn't sure if it have vandos too
Old Sep 6, 2006 | 07:16 AM
ProdriveMS's Avatar
VANOS is only a cam phasing mechanism. It uses a solenoid and oil pressure to advance or retard the cam. Single VANOS is on one cam and double VANOS means it's on both cams(intake & exhaust). Valvetronic is the variable rocker pivot system that changes duration and lift. As far as I know, it was only ever offered in a 7 series. Not on the V10.
Al
