Advanced Engineering Tech For the more hardcore LS1TECH residents
Extending Valve Spring Life?
Old Sep 12, 2006 | 12:45 PM
gun5l1ng3r's Avatar
Yeah what is the problem with desmo? Too much weight in the valvetrain?
Old Sep 13, 2006 | 06:05 AM
gollum's Avatar
Who makes Comp 918 springs? PAC?
Old Sep 16, 2006 | 12:36 AM
Rokko's Avatar
Tech Addict
wow, that slow-mo vid was absolutely amazing. valve springs take a friggin beating. what rpm was it taken at?
Old Sep 17, 2006 | 07:46 PM
PAC Racing Springs's Avatar
Closed ex-Sponsor Account
We have developed and produced most of the high performance beehive springs that are currently available. We have a few extras that will be on our site here shortly.
That video was actually pretty smooth running at 7000 rpm with 0.700 lift on an old NASCAR Truck motor. We are working to get some more that show some pretty wild things going on at higher rpms.
Chris
Old Sep 17, 2006 | 10:41 PM
blackls6's Avatar
A newbie question here: You say you will be using a solid roller cam. What are the advantages of using a roller cam over a hydraulic cam? Can a roller cam be used on the street? What cube motor are you putting it in.
Old Sep 18, 2006 | 11:54 AM
93LS1RX7's Avatar
Roller cam isnt 100% accurate to say in reference to a solid roller. You can have a hydraulic roller too.....
Solid roller cams can have much more abrupt valve events and higher lifts because you dont have to worry about a hydrulic lifter collapsing....It is solid so no collapse. "roller" is just in reference to the ends of the lifters.....roller, flat tappet etc
