LS (2) on MOTEC
If yes, do you:
-running the O2/Lambda sensors (1 or 2??) fulltime (closed loop and paid for it) or used it just for dynotuning?
-fitted a fuel pressure sensor and running closed loop(permanent) as well?
-throttle body/inlet: only MAP or with throttle degree sensor?
-where did you get the wiring harness?
Thanks a lot
Chris.
PS this is a great system for FI aplications
Chris.
