Advanced Engineering Tech For the more hardcore LS1TECH residents
Ls3
Old Oct 28, 2006 | 11:33 AM
  #81
hammertime's Avatar
Originally Posted by chuntington101
ok i have a question, why is GM doing this?? what do they intend to use this engine in?? why didn't thye just use the LS7 in a detuned version??
also on a more technical note what do you guys think GM could get out of the LS7 heads in term of flow?? are they at their limits now as far as a production unit is concerned??
The way I see it, there are two reasons to de-tune the engine. If it is really on the ragged edge, meaning that it is making enough power that it could self destruct in what is considered a normal operating parameter, then detuning by lowerining the output through one of many ways should make it last longer. I don't see this being the issue, as the durability testing I've heard they perform is treacherous stuff - things nobody would ever do to their car. They've tested the platform to a point where they are comfotable that any failures that occur in the field would have happened at any persons hands, not because an enthusaist pushed it too far.
The second reason would be to sell volumes of a lower output powerplant for the potential cost savings. If the heads are being CNC machined at a high cost, they may be able to run them as cast on a less exotic 7.0L engine for trucks. By less exotic I mean pistons, rods and valvetrain more suited for lower rpm and lower accelerations at the valves. I still doubt this engine would replace the 8.1L BBC, but that would be the only way I'd see it happening.
Now whether or not it is a possiblity for the upcoming Camaro is hard to say. There are seveal engines out there to choose from. Seems the L92 might be a good candidate. One thing has changed since the introduction of the LT1 engine - GM has been continually developing their powerplants ever since. If you can believe what you read, the old SBC assembly line had been in use so long it was ready to fall apart. Now newer innovations are coming our way in a span of 5-7 years.
LT1 - 1992, Vortec L31 heads - 1996
LS1 - 1997, LS6 - 2001, LS2 - 2005
LS7 - 2006, L92 - 2007, ???
Old Oct 28, 2006 | 12:18 PM
  #82
Bud M's Avatar
Originally Posted by treyZ28
Have you ever seen a 4.6 DOHC ford engine? Its huge compared a 6.0 GM OHV engine with 25% less displacement! And those engines have very small bores and long strokes. If that thing was even square, it would be much bigger.
I never said OHC was "too" complex; I said it was "more" complex.
All things equal, BSFC is worse with DOHC, which is what I said if you read the fine print. "4 valves... (assuming it requires OHC) "
As a matter of fact I happen to own a 96 Lincoln with a DOHC 4.6. You say its huge but the fact is that if fits fine in a car that is pretty much the same dimensions as a 4th gen F body. And what you think is an engine with a small bore and long stroke has a bore x stroke of 3.55 x 3.54 in. And you keep claiming that a different valve actuation arrangement will make an engine inherently less efficient without offering any supporting evidence. Do you just make this stuff up as you go?
Old Oct 28, 2006 | 09:41 PM
  #83
black_knight's Avatar
Originally Posted by RussStang
Why is HP/L for morons? Just because it is an attribute of an engine that pushrod engines typically don't fare as well in compared to their OHC counterparts? How about torque/L? Can we look at that, and not be considered morons? OHC engines typically do better in that department as well.
Anything/L is meaningless. The only place it matters is in displacement-limited racing.
Old Oct 28, 2006 | 11:45 PM
  #84
treyZ28's Avatar
Are we dancing around the obvious? a DOHC engine is better than a OHC engine. Therefore, the OHC engine can fit in a smaller engine bay: Advantage.
More bore = longer V engine = bigger engine. i
Sorry, it was the 5.4 that was way under square; the 4.6 is just barely undersquare. Either way, both engines are huge and they have less displacement than a gm LSx engine.
Old Oct 29, 2006 | 10:17 AM
  #85
Bud M's Avatar
Dancing around the obvious. Hmmm... how bout this for obvious? 3.55 bore and 3.54 stroke is not "slightly undersquare".
Still waiting for you to back up your claim that OHC is inherently less efficient in terms of BSFC.
Old Oct 29, 2006 | 10:52 AM
  #86
treyZ28's Avatar
Apparently, we gave up on reading too
5.4- 3.5" bore x 4.17 stroke
When you have some sort of data to tell me that spinning 4 cams, opening/closing 2x as many valves and having a much, much longer timing chain is more efficient, I'll say "sorry, I was misinformed." Until then, I'm going to believe what i've heard because it inherently makes more sense.
I'm still waiting to hear about how having a larger engine is advantagous
Old Oct 29, 2006 | 12:15 PM
  #87
Bud M's Avatar
So the source of your vast knowledge on this subject amounts to "what you've heard".
Old Oct 29, 2006 | 12:51 PM
  #88
treyZ28's Avatar
Sorry if logic and a professor's lecture is inadequate for you
I'd still awaiting the source of your information, namely that bigger physical size is completely irrelivant and DOHC has better BSFC qualities
 Michael S. Palmer
Old Oct 29, 2006 | 12:53 PM
  #89
HioSSilver's Avatar
I wish all these guys wanting dohc 4v motors would go buy them. Then I could show'em my p-rod 2v taillights. I ain't had a dohc motor come around me yet. By the way all this comparing to Bmw and Merc is a joke. Go price a crate motor from them. The M3 6 cyl motor costs about 25k. The M5 motor os more than that. Try to modify themm to get more power, you need custom everything$$$$$. Look at the ford cammer motors, alota dough and not much go.
Old Oct 29, 2006 | 10:22 PM
  #90
RussStang's Avatar
Torque/L is meaningless? Is torque/L not a rudimentary way to gauge how effective the engine is at bringing air in. Engines are air pumps after all; this stat is interesting.
I think what you meant to say was anything that makes a pushrod engine look remotely bad is meaningless.
Old Oct 29, 2006 | 10:24 PM
  #91
RussStang's Avatar
Professors can be wrong. You are the one that has made the claims, yet you refuse to back them up. You are not making a very strong point in the process.
Your statement about the 4.6 being slightly undersquare was completely wrong, and yet you ignored the correction completely. Again, you are not making a very strong point with these practices.
Old Oct 29, 2006 | 10:29 PM
  #92
RussStang's Avatar
The price you quoted on the M3 motor was ridiculously exaggerated. I found prices for brand new ones between $10k-$12k, under half of what you stated. How much do you think an M3 costs?
Blown Cobra motors are a lot of dough, but that are also a hell of a lot of go.
Old Oct 29, 2006 | 10:45 PM
  #93
I think you totally don't get my point. Bringing liters into the bottom of the equation only serves to select for less liters. From a performace perspective you want MORE liters, not less. You want to select for more power and a better power band with less weight, cost, external size.
Yes, Tq/L makes a certain degree more sense than HP/L since hp can be cheated by revving higher. But you miss the larger point that selecting for less liters is nonsense. Having less liters won't provide a single iota of performance advantage; in fact it is a big disadvantage. Generally speaking, you want the engine with more liters, not less.
This is not a question of OHC or OHV, although it often comes into play with such debates.
So I maintain my position that HP (or anything else) per liter is pure and total IDIOCY.
Old Oct 29, 2006 | 11:03 PM
  #94
baldurann's Avatar
My dick is bigger than yours. Hah.
Old Oct 30, 2006 | 06:53 AM
  #95
chuntington101's Avatar
good post hammertime! i agree with what you said about the LS7 being a exotic motor and the dutuning business.
all i was trying to say was why not use the LS7 "bits" rather than build a whole new head for a smaller motor?
i guess it was a "in the air" questiuon really but thanks for voicing your opinion.
anyone else want to say something about the WHY????
thanks Chris.
Old Oct 30, 2006 | 07:36 AM
  #96
treyZ28's Avatar
ignored?
Old Oct 30, 2006 | 07:38 AM
  #97
treyZ28's Avatar
specific output is only useful in comparing similar style engines of near equal displacement. Using HP:L to compare a 427ci engine and a 1.3L engine is meaningless.
Old Oct 30, 2006 | 11:10 AM
  #98
RussStang's Avatar
Sure, if the platform can support a bigger engine, and the cost in fuel economy wont be a concern, than by all means, bigger is better. I think you have entirely missed my point. Any engine spec that may make a GM engine look worse than the competition, many guys on here tend to ignore. Torque per liter being pure and total idiocy?! What a ridiculous statement.
Old Oct 30, 2006 | 11:11 AM
  #99
RussStang's Avatar
ignored?
Read it again, for a third or fourth time. The 4.6 is not undersquare at all. So yes, I think ignored is the appropriate term.
Old Oct 30, 2006 | 11:25 AM
  #100
treyZ28's Avatar
I said "sorry, it was the 5.4 that was under square"
I'm not sure how much more attention you want me to give to this slip up. Not that it changes anything, you have a smaller bore engine with less displacement taking up more volume.
