Ls3
The sad fact is the OHC might be needed for emmisions reasons. Im hoping this MDS and DI stuff keeps that problem at bay.
I'm not sure how much more attention you want me to give to this slip up. Not that it changes anything, you have a smaller bore engine with less displacement taking up more volume.
For all intensive purposes, the 4.6 is a square engine, but if one wants to really nitpick, it is oversquare, not undersquare.
But the space constraints have never really been an issue to me. Hell they put Northstars, Small blocks, LS1s, and DOHC V6s in the back of Fieros. Everything I ever need to change on the Fiero I can get to, except the timing belt. But if I'm due for a timing belt change, I'm probably do for a head rebuild and lower end inspection at the same time.
I realize this is not a great comparison, as the two engines have VERY different objectives. But that's my point. The 1.3l is simply on a much higher performance platform than the LS7. But it doesn't mean anything, since the 1.3l would prove to be a very terrible powerplant in a Corvette. But a 1.3l pushrod, OHV motor with a LS7 specific output in a Hayabusa would be just as impractical, needing more cubic inches (Thus space and weight), to make the same amount of accelerative force.
and will affect handling and whether even said engine is able to be installed.
On the OHV vs OHC space constraint, the heads on the OHC are much larger making a 4.6L of Ford DOHC being physically larger than a big block ford and weight is close. All alum BBF is lighter than a 4.6L DOHC. Max cubic inches for a BBF stock deck height is on order of 600 or so cubic inch, max cubic inch of a 4.6L not using 5.4L deck is around 300 cubic inch. BBF of 600 cubic inch, can make around 1400-1500HP N/A with right heads. 300 Cubic inch of max done up 4.6L ford might be able to get close to 700HP N/A.
Physical space of the BBF is close and weight is lighter if you go all alum,
this is how the Space argument came up.
The other argument, was the LS1 was clean on emissions and produce good fuel mileage. Would a 2.3L OHC 4 cyllinder in say a vette produce better fuel mileage? ( Its not guaranteed ), its possible the smaller motor can put out less mileage!
The space argument was for X amount of space in a DOHC I can have quite a bit more space in a pushrod motor, have lowered cost and complexity and make more power without having to turn as many rpm.
Any amount of Cubic inch going from pushrod to OHC is going to take up more physical space and weigh more.
"Curtain area" - is even less relavant to rod ratio and might as well be something along the lines of a bogus equatio of "rod ratio vs oil pressure".
Case in point is two 1.1" intake valves would have a curtain area of 2.2" but would not even come close to the flow of a 2.2" valve, probably at any point on a flow graph. At max lift the single 2.2" valve maxed out ( prolly 450CFM ) would be double what two 1.1" intake valves of same 2.2" curtain area would do.
Where DOHC did make sense was in a 4.125" bore you might have DOHC arragnement of two 1.84" intake valves and two 1.47" exhausts. You might not be able to go much larger. Two 1.84" intakes might be able to max out close to 500CFM with a great port design. Can shut off one intake for running at low RPM and steady state.
Each vavles have their own springs. Lighter valves means float rpm is higher on the graph. Lighter springs can be used to control lighter vavles. Two 1.47" exhausts is overkill since we know for even a 2.15" head a single 1.55" exhaust can be more than sufficient. This is where 3V arragnement came in. Due to lack of need for more exhaust flow.
Blown Cobra motors are a lot of dough, but that are also a hell of a lot of go.
Specific output comparison (HP/L) is useless.
"intensive purposes?"It's "intents and purposes."
The advantage of OHV motors (besides the flow-velocity and thus "torque" advantage) is that for a given amount of weight and space to work with, you can run more cubes with the OHV than with an OHC. Thus it isn't ever meaningful to compare OHV and OHC of the same displacement since the OHV will always be able to run more displacement.
If different configurations of motor can run different displacements, then to compare equal displacement is totally useless. That's why, in this context specifically, the whole HP/L thing is so useless. (it's really useless in every other context as well, but that's another story)
I know this isn't a conventional motor, but it does help to give some perspective. OHC engines can be compact. The Ford motors aren't the end all, be all of OHC engines.
And apologies to the original poster, as this has gone
