Advanced Engineering Tech For the more hardcore LS1TECH residents
Fast 90 Intake porting..
Old Feb 5, 2008 | 06:08 PM
  #281
02402RAMAIR's Avatar
inner and lower are done!
Old Feb 5, 2008 | 07:08 PM
  #282
ROCNDAV's Avatar
looks good.
Old Feb 5, 2008 | 09:46 PM
  #283
Gregory's Avatar
02402RAMAIR: In a couple pictures it looks like the top of the FAST 90 port is larger than the head's intake port. Any thoughts about adding plastic to the FAST 90 or taking some away from the head for a nice smooth transition?
Old Feb 6, 2008 | 09:52 AM
  #284
badmfkr's Avatar
Default Fast
looks like serious heads & intake what cfm are you looking for at low, mid & high rpms?
plus what lift?
on image 4 looks like a small crack.
Old Feb 6, 2008 | 09:55 AM
  #285
The ports are exactly the same. I think what you are looking at is the witness mark. I filled the bottom witness mark in while I was blending in the bottom of the intake to intake port. I left the top witness mark intact. the pictures don't do justice. I can run my fingers through the ports and I have no lips, bumps or edges. I hope all the extra effort pays off.
Old Feb 6, 2008 | 09:59 AM
  #286
above the witness mark is a pocket for the injector. that may be what you are looking at. I did nothing to that area because it does not mate to the head.
should this area be reworked.
I have serched for pictures to give me direction but could not find any.
anyone have pictures?
Old Feb 6, 2008 | 12:05 PM
  #287
ROCNDAV's Avatar
I ended up JB welding my upper corners and radiusing the upper centers. DOn't know if thats better or worse, but my ports match up nice. I recently bought a plastic welder fro Harbor Frieght. I now wonder if that would have been better to use to fill in the upper corners.
Old Feb 6, 2008 | 09:26 PM
  #288
Gregory's Avatar
Thanks! I'm looking for an extra 25HP and 25LBTQ in my combination. I think the porting can get me another ten or so. I may then look for a larger 95mm throttle body and MAF. If I don't make it then I'll add cubic inches and go for fifty more.
Yes, I'm glad you said the ports are flush. Then the pictures are indeed deceiving. It sounds like the FAST ports are fairly close to the head's intake ports.
I added a picture (your picture cropped) and highlighted in yellow the area were the FAST port looks larger than the head's intake port.
Were the gaskets/o-rings very expensive?
Again, thanks!
Old Feb 6, 2008 | 09:29 PM
  #289
Gregory's Avatar
ROCNDAV: How much filler did you need to add in thousands? .050, .100, or more?
Were you able to dyno after the work and measure a difference?
Thanks!
Old Feb 7, 2008 | 09:51 AM
  #290
SSwt00SS's Avatar
02402RAMAIR, great write up and pics my friend. i home ported mine like you and i managed to gain 35rwhp/10rwtq OVER the Ls6 intake I had on my car!!! this is with Patriot Stage II Ls6 style heads (59cc), and a little Comp 224. numbers in my sig...
Old Feb 7, 2008 | 11:43 AM
  #291
ROCNDAV's Avatar
Thanks!
I roughed up the corners of the intake then built up the area with the JBweld (couldnt tell you off hand how much, just enough that the intake port was now smaller than the head port).
I purchased some 6mm threaded rod and made some stud like fixtures to torque the intake down and used an air grinder to make ports flush.
I haven't dyno'd anything, so I cant tell you if I helped or hurt anything.
Old Feb 7, 2008 | 01:43 PM
  #292
AmericanMuscle313's Avatar
Do you happen to have any before and after pictures you could post?
Old Feb 7, 2008 | 03:21 PM
  #293
I have the old fast 90 base I busted due to a n20 backfire. I will take pics of it to give you a look at the unported one. I will post later tonight.
Old Feb 7, 2008 | 05:37 PM
  #294
Here is pics of my old unported fast base (n2o backfire busted it) and the new ported and filled base.
unported on AFR225 head
ported and filled base on same AFR 225
Old Feb 7, 2008 | 05:41 PM
  #295
AFR 225s hand ported and polished ( almost done)
Old Feb 7, 2008 | 05:45 PM
  #296
Again, thanks!
that area is open for the injector. (pic below)
I don't know if it would help to fill this area or not.
ANYONE know what to do to this area?
Old Feb 13, 2008 | 11:34 PM
  #297
Chevy406's Avatar
Last Saturday I pulled my FAST to check for a possible vacuum leak. While I had it all disassembled, I decided to match port the bottom shell to the stock LS1 heads, and open up the runners a little.
This is the unported FAST bottom sitting on the stock LS1 heads - notice the heads showing up on the right and slightly at the bottom.
I stuffed rags down the intake runners, and match ported the heads to the intake using a die grinder with carbide bit and sandpaper rolls:
I also opened up the center piece a little
As I re-assembled the intake, I went ahead and added a set of 30# SVO injectors to replace my stockers:
My stock combination was not tested, but I will have the current setup dyno tuned next week. So unfortunately I can't add any concrete data to this discussion, just sharing how I spent my Saturday afternoon.
Old Feb 14, 2008 | 08:56 AM
  #298
badmfkr's Avatar
Default Fast
is you're intake a 78mm or 90mm?
the hole on the intake is to big, I would be mad at Comp. for poor quaility control.
I think the car will run much better now that you smoothed it.
where are you having it dynoed an tuned Trussville?
Old Feb 14, 2008 | 04:49 PM
  #299
Chevy406's Avatar
My intake is a 78mm. I bought it used for roughly the same price as an LS6 intake. I haven't been able to run it hard since re-assembling it because with the 30# injectors and no tuning it goes to 9:1 AFR at WOT. Yes, I plan on a trip to Trussville next week. I would have run down today, but decided spending V-day with my wife was a better decision in the long term...
Old Jul 3, 2008 | 11:44 AM
  #300
LS1C5Vette's Avatar
When you guys open up these intakes are there and special sealants or ATV that need to be applied when you re-assemble the intake? I have a 78 intake I plan on doing this on.
