Flex Fuel related Q
And how long would you say it would take an F-Body to go to crap from running E85 through it daily?
He is past the 2 year mark so far.
I might change the fuelpump next year to a bigger one... pics of the old one will be posted.
Fuel systems have to be compatible with 10% ethanol by law, there is no reason to assume that at say 40% they would fall apart. It doesn't make sense that GM would only put in parts compatible with the minimum.....or does it? You may have trouble with some fuel pumps at 85% alcohol. High alcohol % attacks the epoxy that hold some of the motors together.
Theorethically, the gain is 5% just by switching fuel. 350 hp X 5% = 15 hp, plus what can be gained from timing.
