Can someone clear up this "myth" for me.
They have small displacement DOHC turbo motors. Their small displacement means small stroke, and the small stroke allows them to complete more cycles per minute - greater RPM's (if the piston has a shorter distance to travel, it will be able to achieve more cycles in a given amount of time).
Once again, HP = TQ x RPM / 5252
So even though they don't make as much TQ, they can achieve greater RPM's, which shows you why they can make so much more HP than TQ.
Picture it - Your HP is equal to the amount of force one cycle the engine makes, multiplied by the number of cycles the engine makes in 1 minute. The 5252 is just a constant used in converting the units between TQ and HP.
Let's take a 346 and stroke it to a 383.
So keeping all other things equal, what we did was increase the stroke of the engine which will yield more TQ per stroke. Since other things were kept equal, the piston speed has not changed. It will now take that piston a little longer to move up and down the cylinder since the stroke is longer. Therefore, obviously you won't be able to achieve quite as high RPM's as before.
So we are gaining torque and losing a little bit of RPM's. Since everything else was kept the same, you are going to gain enough TQ that it will be worth losing the little bit of RPM's and overall you will gain some HP (which is what matters).
Woah! Let me understand you:
Since you have increased the stroke, the piston speed has not changed?
So...with a 3.62" stroke on a stock LS1 motor, the piston speed is the same
at 3000 RPM with a 4.0" stroke?
Gee, that's like saying a swimmer has 10 minutes to complete 10 laps in a 100 ft. length pool.
If the pool is extended by an extra 20 feet and he still has 10 minutes to complete 10 laps, does that mean he's still swimming at the same speed?
So an 346 LS1 engine turning 5000 RPM has fired more power strokes than
a 382 LSx turning 5000 RPM?
Hmmmm...so if 5000 revs per minute is 5000 revs per minute... what happened
to those extra power strokes?
i.e. PS increases wrt to angle even before you have scaled it for the RPM in question:
In the graph:
R is half-stroke (the radius of the circle that the center of the crank pin traces out),
L is the rod length,
Vertical units are inches (position wrt crank center), inches/radian (velocity), inches/radian² (acceleration),
Horizontal units are degrees (crank position wrt TDC).
Sounds like this could end up being a continuation of the "clear up this myth" thread.
But if it were up to me I would build the larger bore/shorter stroke. I would like to see what the difference would be of these new L92 heads and the larger valves flowed on a 4.125 Vs 4.25 bore. Would be interesting. I wouldnt expect much of a difference, but it should show up.
absorbed that information and took it to the bank.
There are about 3-4 people in this thread that really know what's going on,
and post their knowledge to help everyone understand...then it gets lost
in a post that totally contradicts the facts with a little ego thrown in for
good measure.
It's nothing personal, it just gets annoying after a while.
Oh well, you will still lose some RPM's so it doesn't change the result.
All I am saying is this. A smaller engine with very short stroke is capable of greater RPM's than a larger engine with a very long stroke.
I don't see how this is so hard to understand.
Look at 600cc crotch rockets. They make a lot more HP than TQ and they do it at like 14,000 RPM for this very reason.
As for the motorcylce analogy, it seems you may have "the cart before the horse".
Does the displacement of the motor lend any hints as to why such high RPM
is required to make power?
Let's not start comparing motorcylce engines to car engines. Rotating and
reciprocating mass is much less in a motorcycle engine.
