Too much bearing clearance?
This is simply just wrong. Many high performance engines will run close to this spec and beyond. I have ran several aluminum rod engines with .045-.080" (not actually by choice, but because of the way the crank was ground on the cheek clearances) and had 0 problems and wonderful oil psi both hot and cold and both at idle and HIGH RPM. Sometimes experience well outweighs what you read in a book.
Lots of things work out to be like this in this area of performance rebuilding. OE stock specs are not always what is preferred when building High Performance, alot of times YES, always NO. Bret
If you had the same .002 of oil clearance and then had .008 side clearance the side clearance will be just as much of a limit to oil flow. The same with .003 of oil clearance and then had .012 side clearance. If you have .015 and you still have the normal .002-.003 oil clearance then the bearings are limiting the oil flow more.
impedes oil flow to the bearings at high RPM?
Maybe I have the term mixed up with another...I recall reading that recently.
99 per cent of these aftermarket cranks and rods have around .020 -.025 side clearance and if you run tighter oil clearance they will have higher oil pressures. They also are more likely to spin a bearing if they are too tight even though the oil pressure will always show higher when you tighten the clearances up. If you go under .001 clearance and use the right springs you can achieve over 100 PSI oil pressure and can almost blow the filter right off the engine as well as probably spinning all the bearings.
High oil pressure does not mean that you are getting the right amount of oil by the bearings and also does not mean you have the right clearance but rather it is just a measure of restriction and oil viscosity really.
If you run the right clearances you will have lower oil pressure than our example above and also will not have any bearing problems with higher rpm and more power. Oil pressure is a measure of restriction and if you have much higher oil pressure it means less oil is flowing through the bearings if nothing else has changed not more.
Saying all this I don't mind having tighter than .0025 side clearance either but more engine builders I know LIKE the side clearance to be .020-.025 so 90 percent of your aftermarket rods are made like that. A SBC rod journal is 1.900 across and the rods are usually .940 wide so you are right at .020 basically right away and the journal width is usually even a little over 1.900 in reality so you end up at .020-.025 usually.
