Too much bearing clearance?
High oil pressure does not mean that you are getting the right amount of oil by the bearings and also does not mean you have the right clearance but rather it is just a measure of restriction and oil viscosity really.
If you run the right clearances you will have lower oil pressure than our example above and also will not have any bearing problems with higher rpm and more power. Oil pressure is a measure of restriction and if you have much higher oil pressure it means less oil is flowing through the bearings if nothing else has changed not more.
We have worked on some wet sump engines with pistons guided rods that have about .100 side clearance and they run the same oil presure as all the other engines. HMMMMMMMMM
Mercedes was the first to come up with the piston guided rod engine years ago.
-Ben R
