Technical info on rotary valves?
Most of the marketing out there by companies like Coates seem to indicate that the biggest issues (sealing, lubrication) have been solved.
Obviously a $15,000+ valve train would not make much sense if you could not make a reliable 10,000+rpm. Coates apparently had a Ford 5.0 motor run to 14K but for how long?
Costs would likely be even higher considering a decent FI or ITB setup would help get air in at those high rpms.
Found one although it's dated for 1994-95
Nate
