Advanced Engineering Tech For the more hardcore LS1TECH residents
Oil pressure in head
Old Dec 18, 2006 | 06:21 PM
A502slo's Avatar
Default Oil pressure in head
On a boosted engine. We are trying to limite the oil pressure to the head. Right now we have to much oil pressure in the head. Can someone with a boosted engine please help here. This is on a Ecotech motor with 45psi of boost. i know i am not giving much info here, but please help me with any info if you can. We were told that we need a oil pressure regulator. How does that work and where do you install it.
Old Dec 19, 2006 | 09:53 AM
mrdragster1970's Avatar
6 & 8 Second Club
You didn't mention what kind of system you have??
I only know about Chevy stuff, but on a dry sump the regulator is built in,
we have a bolt that controls max pressure, you can't miss it.
Which is the same for any kind of motor.
If you're still using internal stuff, I have no idea.
Old Dec 19, 2006 | 09:57 AM
John_D.'s Avatar
Yes, if it's the stock internal oiling, then you'll need to know the oil routing.
If you can install a restrictor in the oil passage to the ohc stuff, without reducing the flow to the mains, then you can probably do it this way.
If it's going to restrict the mains, then you'll have to modify the oiling system so the top end and the bottom end are fed separately, or so the bottom is fed first.
Old Dec 21, 2006 | 12:16 PM
AshWS6's Avatar
outlet of the pump, blows off excess pressure... most pumps have shims you can cut some spring or shim out to lower the venting pressure
Old Dec 21, 2006 | 12:28 PM
Sean Collins's Avatar
The know it all's know it all
I assume you are getting o much oil in the cylinder head ??? you can run restricted tip pushrods without to much drama. It will allow your to not open the motor or go to deep to correct the issue If i am reading this correctly.
