Destructive forces inside the rear differential
I would like to hear more about case flex. It seems unlikely that the gears themselves are to blame. If they are inadequately held in place and are allowed to separate under load they will lose teeth. Furthermore, who is blowing up their rear ends, is it people with stock gears (ie set up by GM) or people with replaced gears (ie aftermarket set up the gears, possibly incorrectly). Lack of carrier preload (most people give little credence to needing to take a lot of care or measurement of it) could be killing a few of them.
I also know (or read on this board) of others who break them leaving a parking lot.
For me, I think the T2R diff made the difference.
In Any Case I Just Ordered A Dana 60 Setup After My Fully Built 10 Bolt With An Auburn Race Posi Lasted Me 10 K Miles
1. For the pinion we have possible deflection in the pinion shaft and pinion support-->housing
2. For the ring gear we have deflection in the ring gear, carrier, main-caps, and housing
Does anyone have specs on the pinion shaft diameter between the 10 bolt and 12 bolt? I'll bet the weakness of the 10 bolt is in the housing itself as stated before and its ability to resist deflection under high torque loads. If this is the case I believe a great deal of strength could be added to the housing by adding truss supports. Many off road truck owners with with big tires and ultra low final drive ratios in the order of [(70-100):1] truss their axles (then there problem becomes breaking axle shafts!)
My gears from GM came set up noisy as hell, and it took them 4 times to set them up right. Unfortunately, there is now a great deal of play between the ring and pinion - you can turn it about 5 degrees or so before one contacts the other (might be exaggerating, but it is a lot more than I think it should be). This rear has held up to my sticky clutches, but I've never run sticky tires. The rear is now starting to make some more noise (whining, clicking, etc), but is still holding in there.
i had the stock cover too. i know it had a minimum of 250+ track passes with 1.52-1.80 60's on it, i launched it off the transbrake on the kit more times then i can remember. when it broke i had just had the 370 tuned on the kit which did 510rwhp through the th400. after it broke i sold the ring & pinion and axles which were still in good shape.
a lot of the failures i have seen are with aftermarket gears. i've seen 2 of them with 4.10's that broke & i know they were not installed correctly and sounded like a 2 yearold screaming.
I didnt know the pinion nut was supposed to be 150ft/lbs which is a bit.
After a year later it slowly gave away (I knew it was cause of the screaming)
then I took a turn and it all fell apart. shattered teeth and cut up my ZT.
Now I put the 3.42s back in and its going good
And do you know why is is called Finite Element models?
