Some welding chemistry questions.
And why do you have to switch the polarity if your using flux-core? Why does it matter which way the current is going?
And why exactly do you need shielding gas in the first place? I know that you get a crappy weld that doesnt stick without it, but why? What in the atmosphere messes up the weld?
Im not looking for a "cuz it werks bettar" answer. I wanna know the chemistry behind these distinctions. Thanks guys!
I kinda thought it had something to do with the heat igniting something in the atmosphere that tainted the weld.
As for the polarity, I think that the metal actually has a tendency to 'move' or flow in the direction of the current.
I also believed that the reason for the inert gasses was to keep the content of the sourrounding atmosphere a constant mixture. I think that when you go from c-25 or tri-mix you also go to a different material being welded than if you used the argon/CO2 mix.
Just my $.02
EDIT-> Upon further thinking, reaction do tend to happen faster in the presence of more heat, so the second poster might be right, even if C25 and tri-mix have O2 in them.
Al
The tri mix gases are typically used with regular carbon steel with trace amounts of oxygen or in the form of CO2. This provides a small amout of oxidation which creates extra heat in the weld puddle, giving better penetration. Argon is a very dense gas which causes quenching in the weld area, creating less heat and poor penetration. It is also more expensive. CO2 BTW is not inert, but very stable since it has 8 shared electrons in its outer shell (called a stable octet). If they use a helium which is light better penetration can be had due to its lower quenching, but you need more gas to shield the puddle.
It is kind of like heat treating with water or oil. Oil is lighter so it quenches slower and water more dense and quenches faster.
With Stainless Steels you will typically see pure inert gaes being used, if it is a mix it may be of Argon and Helium combined to generate more heat.
I have not been in this feild for 10 years or more but that is what was the standard back then.
BTW for heavy weldments 1/2"+ real Fluxcore rocks and will be stronger than GMAW (Mig) any day of the week.
Try to keep a consistant 3/8th's stick-out.
Remember, watch your electrode angle, travel speed and stick-out.
Some information, there is lots out there.
http://www.thefabricator.com/ArcWeld...icle.cfm?ID=10
Yeah, I figured out how important the electrode angle is to welding. It is LOT harder than it looks!
"One of the critical aspects during the refinement of steel is to prevent oxidation. This is why deoxidizers are added to melts and why high-alloy steels are refined under vacuum. At ordinary temperatures, any oxygen combined with the iron in any steel will be in the form of iron oxide, which is weak, brittle and totally undesirable in steel. At elevated temperatures iron combines readily with oxygen to form iron oxides which then remain as inclusions in the cooled steel. It is therefore necessary to protect steel being welded from the oxygen in the atmosphere. In TIG and MIG welding, this protection is provided by the inert gas (argon or helium) that shields the weld area. In arc welding and in the various brazing processes, the protection is provided by the flux. In oxyacetylene fusion welding the protection is provided by the shielding action of the outer envelope of the gas flame.
HOWEVER, it is not quite that simple. In order to provide the required protection the envelope must be of the right composition. Pretty obviously, for instance, an atmosphere rich in oxidizers is going to be of no help at all in shielding the molten metal from oxidation—and that is exactly what we have with an oxidizing flame. When you see someone attempting to weld steel with even a slight excess of oxygen you are watching ignorance at work—and the creation of a burned and brittle weld."
Vernon
1, 2 , 5, 9 and 12 require some external shielding to aid in protecting the molten metal
fcaw
dcep 1 2 3 4 6 9 12
dcen 7 8 10 11 13 14
both dcep and dcen 5
with dcen your + ions flow from the workpiece to the electrode
and your - electrons flow from the electrode to the work piece
This will penetrate deep and narrow
the heat balance would be approx 70% on the workpiece and 30% at the electrode
DCEP is the exact opposite
The shielding gas is to protect the molten metal from impurities in the air
Im not sure of the chemical composition of the impurities but like said above
can lead to discontinuities like porosity...your weld will look like a sponge
A flux will help float impurities off the metal and protect from impurities in the air
Shielding gas is also sensitive to drafts and wind which may blow the gas away leaving the weld unprotected
Craig
Vernon
CANAM doesn't exist anymore, unfortuntely. I like his books.
