OHC vs Pushrod
http://www.cheersandgears.com/forums...opic=15551&hl=
It basically reaffirms what most of us all say here, get the air in and get the air out. Even uses the LSx engines in its comparison to other OHC engines.
It does a good job of pointing out the Pros and Cons of each engine out there.
I don't think that the write-up in the link is attempting to be comprehensive regarding the latest state of technology of pushrod engines. I think that this guy is just saying that it is a commonly held misconception that overhead cam (SOHC and DOHC) are superior in every way to pushrod engines. He's also debunking the myth that pushrod engines are outdated. The write-up also mentions that OHC engines have been around for a long time and they are not the latest nor the greatest in every respect (power versus weight, engine exterior volume versus power, etc.).
Yes there are probably a lot of other things that could be said both for OHC and pushrod designs. However, I think that this guy was just trying to set the record straight to the extent that he could.
Steve
One EXTREMELY important point they missed (also something that ricers cannot get through their heads) is that the smaller an engine is, the more HP/L it is capable of. Or more precisely, the shorter an engine's stroke is, the more HP/L it is capable of.
Obvious reason being: shorter stroke enables greater RPM's. This is why tiny crotch rocket engines can achieve nearly 200 HP/L at like 14,000 RPM's.
All the way through I was thinking to myself, "What about the bottom end?" In the end the ultimate potential to develop power in all engines is limited by piston acceleration forces.
GM will never let the pushrod design die(at least i hope)
Unless GM dies.
For the LSx engines it isn't just down low where all the power comes in, but it can still be felt up top. Everytime I go from my GTP to my TA and go WOT, it amazes me how it is a nonstop and consistant pull on the top side, the GTP falls off after a bit and starts to struggle.
and yes you can have a pushrod 4valve cyl head. the ford 6.0L TDI, yes a diesel but still a pushrod, the rockers on that engine control two valves, why no one else tried this theroy in a performance engine i dont know,
but i think it would be a good idea for more airflow IMO
I'm new to both this forum, and the world of large displacement V8s.
Q:
Does anyone know anything about the heads on this engine:
http://tinyurl.com/3bu277
(I was hoping for something other than the evils of the OHc layout...)
Thanks
EVER!!!!lol
