Air-Fuel-Ratio vs. power
This is two back to back runs with a modified 3.4 DOHC engine I had. The only change was a different IAT sensor. Obviously it was very poorly tuned, but notice the power increase and spike advantages of the leaner curve. Also notice that the steeper acceleration rates go right inline with the lean spikes in the A:F ratio.
quantitative measure of engine output across the RPM
band.
A flat stretch of road on a still day, and an accelerometer
would do as well; locked converter rolls from 40 to 80MPH,
or whatever you can do for maximum consistency / least
sources of variability.
If you can "shotgun" fuel and spark as independent axes
(safely) for a matrix of tunes, accumulate the acceleration
data and overlay the curves in an Excel plot you can pick
off the "top line" and its EQ, advance values are what's
right at that RPM. Which line wins at any point, may
change but you can follow it back to the fuel & spark
each point along the way.
It's work, but it should be relatively pleasant.
I have bought Analog Devices accelerometer eval
boards that provide 2-axis, voltage-mode accel
outputs for about $30 and with another $5 of
Radio Shack parts (or the European equivalent)
you can have an accelerometer box that plugs
straight in to your HPTuners Pro cable and log
acceleration to your heart's content.
I don't think you can get a clean answer, but you
could provide the first
From what I've seen on engine dynos (I'm a calibration engineer), below 12.5 will reduce power a tad. Into the 11.8's, and you're down maybe 2 percent. 11.5's and you're down a few more percent. 12.6-13.1 won't change much. 13.8 will be down a few percent again.
EGT is a very important thing to consider as well. I usually see 12.5-12.8 without EGT problems, unless the timing is too retarded. 12.0 is cooler yet. 13's and up are pretty hot.
I agree with a previous poster's tuner's comment about set WOT A/F to safe (EGT, knock), and get power with spark without tickling the knock sensor too much. Don't go too low on spark either, as any wasted efficiency goes to EGT and the cooling system.
How far from the heads?
Do you need to measure each bank separately?
Do you need to merge the gasses of the 4 cylinders of the same bank?
Or can I chack just one cylinder (for example using the AIR or EGR manifold flange)?
What are reasonable temperatures for NA / FI?
I know EGT is used for tuning, but I don't have a clue. I only go by wideband.
But it's interesting to see, the steepest acceleration slopes coincide with the 2 "lean" spikes, and the blue curve is higher beginning to end, and it is also the slightly leaner curve. So nothing we didn't already know, just thought I'd throw it out there. Plus, don't even try to tell me you don't like checking out dyno runs, imagining what driving that car might be like
12.8 at torque peak
13.0 at HP peak
12.5 for auto X-ing
A local tuner uses 13.2-13.5
Nice numbers, but wo made a test?
I'd like to see a dyno graph of the same car with different AFR (like 11.0 - 11.5... up to 13.5)
Thanks!
Stefano
currently on my FI setup i'm running 12 almost across the board..more like 12.3 down low
I tune it to have 12.5 with water alone, then add 5GPH of 50% ethanol what brings the AFT 0.5 points lower (12:1). This starting from 1 PSI.
How far from the heads? As close as convenient, or about 3" if possible.
Do you need to measure each bank separately? Only if you care about it enough. You could also pick a "known" hot cylinder.
Do you need to merge the gasses of the 4 cylinders of the same bank? No need, unless you're measuring cats.
Or can I chack just one cylinder (for example using the AIR or EGR manifold flange)? Yes, but make sure the tip of the thermocouple is in the flow a ways (try for middle).
What are reasonable temperatures for NA / FI? NA 850°C is very dangerous, try to keep below 800°C (usually not very close to that on the stuff I work with in China). Depends on the valve and valve cooling, though. FI will be higher, regardless, just keep it rich enough to avoid detonation without extreme retard, and build it with good valves and extra attention to the exhaust cooling ability (seat width, cooling flow in that area, guide thickness).
I know EGT is used for tuning, but I don't have a clue. I only go by wideband. It's not terribly important for most people, until you start doing top speed long distance stuff (like we do with OEM calibrations), or are nitrous/forced induction (or both). Drag racers expect to go through engines before the valves go anyway
, and as long as the tune isn't terrible, it won't be a serious problem. Towing guys should pay attention though. There Are A Tremendous Number Of Variables That Come Into Play In This Type Of Question. When You Find The Perfect Air/fuel Ratio For Any Point In Your Power Curve, That Perfect Ratio Is Only Perfect At That Air Temperature, Cylinder Temperature, Plug Temperature, Mixture Velocity Through The Port, Mixture Velocity Through The Squish Area (piston And Chamber Design As Well As Proximty Of One To The Other), Fuel Atomization, Timing, Etc, Etc, Etc. I'm Sure There Are Many Others That I Can't Think Of At The Moment, And Many More That I Can't Even Imagine! (and I've Been Doing This For A Very Long Time) My Point Is That The Only Method To Find Optimum A/f Ratio And Timing For That Matter, Is The Scientific Method. I.e. Controlling And/or Recording As Many Of The Known Variables As Possble And Making Small Changes And Recording Those Results And Then Verifying Those Results. Thusly The Only Way To Accomplish This Is With Some Way To Quantify Both The Baseline And The Changes. A Dynomometer Is By Far The Best Way To Do This. There Are Of Course Other Ways, They Are However Less Scientific As You Have Less Control Over The Variables.
Now That I've Said This, I Need To Say That As Soon As You Change Any Of The Variables The Optimum A/f Ratio And Optimum Timing Change. Weather Changes, Mechanical Changes (even Of A Very Small Nature), Etc ,etc Have An Effect.
If One Is To Quote A/f Ratio's As A General Guideline, Then They Should Be Quoted On Generally Accepted Safe Parameters. 12-12.5 For Na Applications. This Is Not To Say There Wont Be A Better A/f Ratio For Your Particular Application, But Merely To Say That If You Wish To Maximize Your Tune You Need To Quantify The Optimum Results.(dyno, Track, Performance Meter And Consider The Enviroment). Dyno Tuning Is Best Because You Can Establish The Perfect A/f Ratio And Timing At Every Rpm Point In Your Power Curve (limited Only By Your Patience And $$). No Other Measure Of Performance Is As Valuable As The Other Methods Can Only Average The Total Performance Change.
Sorry About The Long Winded Opinion But It Is A Complex Question.
Jack.
There are a tremendous number of variables that come into play in this type of question. When you find the perfect air/fuel ratio for any point in your power curve, that perfect ratio is only perfect at that air temperature, cylinder temperature, plug temperature, mixture velocity through the port, mixture velocity through the squish area (piston and chamber design as well as proximity of one to the other), fuel atomization, timing, etc, etc, etc. I'm sure there are many others that i can't think of at the moment, and many more that I can't even imagine! (and I've been doing this for a very long time) my point is that the only method to find optimum a/f ratio and timing for that matter, is the scientific method. i.e. controlling and/or recording as many of the known variables as possible and making small changes and recording those results and then verifying those results. Thusly the only way to accomplish this is with some way to quantify both the baseline and the changes. A dynamometer is by far the best way to do this. There are of course other ways, they are however less scientific as you have less control over the variables.
Now that I've said this, I need to say that as soon as you change any of the variables the optimum a/f ratio and optimum timing change. Weather changes, mechanical changes (even of a very small nature), etc ,etc have an effect.
If one is to quote a/f ratio's as a general guideline, then they should be quoted on generally accepted safe parameters. 12-12.5 for NA applications. This is not to say there wont be a better a/f ratio for your particular application, but merely to say that if you wish to maximize your tune you need to quantify the optimum results (dyno, track, performance meter and consider the environment). Dyno tuning is best because you can establish the perfect a/f ratio and timing at every rpm point in your power curve (limited only by your patience and $$). No other measure of performance is as valuable as the other methods can only average the total performance change.
Sorry about the long winded opinion but it is a complex question.
Anyway: thanks!
Actually I know car stuff better in English than in other languages (all I know comes in fact from this plus a couple of other forums)
About the AF-ratio (actually the starting point of this thread): I understand that it's much more complicated than what it looks like.
I'll stick with a conservative tune (stock timing table) and 12.5 for NA.
When the blower is ON I go 12 AFR, spray some alcohol and go low in timing to 17*.
A G-meter could help to find out a better setting... actually I should check how flat my wife's ***** become during aceleration...
DD > D > C > B > A > FLAT!
(it's clear she doesn't know I'm posting here). Alcohol (Methanol) - Alcohol is usually used in the form of Methyl alcohol or methanol. CH3OH is the chemical formula. Methanol burns at a much richer mixture than gasoline does, between 5.0:1 - 6.0:1. That's 5 lbs of air to one pound of fuel. Methanol has approximately 9,500 BTU/lb. Using our 355, example above, SBC consumes 567.53 cfm @ 6500rpm which is 42.64 pounds of air and now at 6.0:1 ratio for Methanol is 7.11 pounds of fuel. Therefore if we are using Methanol fuel our engine is producing 67,545 BTU's of energy at 6500 rpm.
Nitromethane - is a fuel that is used mostly in specialized drag racing classes, "nitro funny cars" and "top fuel". Nitromethane's chemical formula is CH3NO2. The oxygen in nitromethane's molecular structure means that nitromethane does not need as much atmospheric oxygen to burn, part of the oxygen needed to burn nitromethane is carried in the fuel itself. Typical A/F ratio for nitromethane is 1.7:1 and nitromethane has an energy content of 5,000 BTU/lb. Using our 355, example above, SBC consumes 567.53 cfm @ 6500rpm which is 42.64 pounds of air and now at 1.7:1 ratio for nitromethane is 25.08 pounds of fuel. Therefore if we are using Nitromethane fuel our engine is producing 125,412 BTU's of energy at 6500 rpm.
TABLE 1 Fuel Engine Air Flow (cfm) lbs of air (lbs) A/F Ratio Pounds of Fuel (lbs) Energy Content of Fuel (BTU/lb) Total Thermal Energy (BTU)
Gasoline 567.53 42.64 12.8:1 2.89 18,500 53,176
Methanol 567.53 42.64 6.0:1 7.11 9,500 67,545
Nitromethane 567.53 42.64 1.7:1 25.08 5,000 125,412
Summary - As you can see from table 1 above the clear winner is nitromethane. But that doesn't mean to go out and pour nitromethane in your car and see how it runs, if you do your engine will surely blow up. Nitromethane is very expensive and dangerous to handle. The interesting alternative to gasoline is Methanol. Methanol will make more power, typically around 20% more power than a similar engine running gasoline. Some things to consider in running methanol is your fuel system will have to be completely changed / upgraded. Based on the table above the fuel system will have to flow approximately 2.5 times as much as the gasoline engine.
I guess the old saying is true. "Gasoline is for washing parts, alcohol is for drinking and nitro is for racing."
Obviously on a flat road etc.
If you can log rpm vs time then its fairly easy to do back to back tests this way.
Im still not convinced pushing a boosted engine into the 12.x AFR range is safe enough to warrant the risk. Keep it in the 11's for all the power it will cost you. Engine longeivity is much more important IMO.
Aside from that...anyone know any way of hooking up an EGT prove that will output a 0-5v signal for logging ?
I do have a Greddy EGT guage, but its kinda hard to watch that, and the road at the same time.
