Advanced Engineering Tech For the more hardcore LS1TECH residents
Is tire width as important as we think it is?
Old May 22, 2007 | 11:14 AM
  #61
slt200mph's Avatar
What math symbol do you use to inter the koolness factor of wide tires into your equation..
Old May 22, 2007 | 11:24 AM
  #62
98TADRIVER's Avatar
Originally Posted by treyZ28
The rubber compound (sidewall and tread) along with tread pattern make a huge difference. Hop on a sport bike with shitty tires and then on one with good tires. As a matter of fact, I'd suggest a bike to anyone who wants to experience this stuff. Everything from powering through corners to chassis flex to the importance of good rubber.
so do you agree or disagree with me? lol
Old May 22, 2007 | 12:12 PM
  #63
MrDude_1's Avatar
12.
as in 12 inches wide looks friggen cool.
Old May 22, 2007 | 12:14 PM
  #64
sawedoff's Avatar
Talking
Originally Posted by 99ws6taconvertible
Like I always say...college kids are dumb...this section should be renamed to 90% 1st year engineering students and 10% ppl who know wtf they're talking about tech...Do you honestly think your 3 variable equation in physics I can be applied here? Wait till you get out of college and get some real and practical knowledge and sense before you try and solve this with math.
This could equally hold true for just about any automotive forum. Where there's dudes, and cars, there's lots of bullshit lies. Always has been. Nothin's changed. It gets so deep a man has got to pull up his pants legs. lmao
Old May 22, 2007 | 12:24 PM
  #65
slt200mph's Avatar
Originally Posted by MrDude_1
12.
315, 325, 335, & 345 = 12+ in. = KOOL
Old May 22, 2007 | 12:54 PM
  #66
MrDude_1's Avatar
man tires are measured in inches......
thoes are treaded girly tires.
Old May 23, 2007 | 01:28 PM
  #67
NC98Z's Avatar
When I bought my Z used it alrady had 11" rims on it so I don't have much of a choice. Now if I can just figure out why Nitto 315/35/17 drag radials are narrower that 315/35/17 BFG drag radials.
Old May 23, 2007 | 03:59 PM
  #68
treyZ28's Avatar
yea.. but that can set you into a diffrent mindset too.. i can have you hop on a bike with a 160 tire... and then goto a bike with a 180 or 190.... and suddenly you think.. WOW, i turn a hell of alot better with that 160...
Good point
Old May 23, 2007 | 04:00 PM
  #69
treyZ28's Avatar
Nonsense. The students questioning aren't the dumb ones.
Old May 23, 2007 | 04:01 PM
  #70
treyZ28's Avatar
Neither. I'm saying there are more variables than simply tire width.
Old May 23, 2007 | 04:34 PM
  #71
proporio's Avatar
Found this, some interesting info,
Importance of tire compound
http://unisci.com/stories/20022/0612023.htm
Old May 24, 2007 | 10:29 AM
  #72
gun5l1ng3r's Avatar
From the above link:
"In contrast to dry-weather tires in Formula One racing, which exude resins and actually even out irregularities in the asphalt, thus considerably improving the area of contact, normal tires do not secrete any fluid since the disadvantage of "Schumi" & Co's good road holding properties is the considerable tire wear. Racing tires are literally sucked dry."
I want some F1 tires on my car, if only for a few hours...
Old Jun 25, 2007 | 11:42 AM
  #73
South's Avatar
Originally Posted by mpe488
Have you ever heard correlation does not imply causation?
Please see attached...
Attached Thumbnails Is tire width as important as we think it is?-n122614476_31948719_8205.jpg
Old Jun 25, 2007 | 11:43 AM
  #74
FieroZ34's Avatar
That's awesome.
Old Jun 25, 2007 | 02:05 PM
  #75
Ruckus46Gt's Avatar
does the amount of extra traction given by wider tires compensate for the extra weight however
Old Jun 26, 2007 | 03:59 AM
  #76
nogaromariner's Avatar
Default F1 Tires?
F1 Teams dont develop their tires, they are provided to the teams at each race from one manufacturer. They can select from up to 4 compounds, however only 2 are available per race. The move to grooved tires from slicks was a rule change designed to reduce maximum speeds. Similarly wheel size is dictated by the rules, I believe OZ makes all of the wheels to spec, the only variation being the drive splines...each team has their own hub design. The sidewalls are incredibly stiff, in contrast to a drag tire. This allows for stability during cornering. It would be easier to use a larger wheel, lower profile as someone stated earlier..but the rules do not allow it.
Old Jun 26, 2007 | 08:33 AM
  #77
MrDude_1's Avatar
are we talking drag racing, autocross, tight roadcourse, or long roadcourse?
i suppose the generic answer for them all would be, if you're not hooking with what you have.. yes. it should help. lol.
Old Jun 26, 2007 | 01:44 PM
  #78
Derek 357i's Avatar
There is one tire manufacturer, but several wheel manuf. Enkei makes McLarens, BBS makes Ferraris, don't know about the others...
Old Jun 26, 2007 | 10:13 PM
  #79
Alvin's Avatar
I didn't read the whole thread so I may have missed it...
I didn't see where anyone mentioned the force balance at the surface of the road and the tire surface. For things to remain static (which they are in a tire/road situation) the force done by friction must be less than what will shear the rubber. If it doesn't you spin out and leave nice black marks and go into the wall.
By the same logic that started this thread you could say.. hell the weight of the car doesn't matter. F= uN for those who forgot. Obviously it does and ONE of the reasons is what I mention above.
Engineering is making a good balance of what you have available. There are no simple answers like throwing on a set of wider tires because obviously there is some negative recourse like the power to turn that extra tire.
There are a ton of factors that determine which tire is best for each application. One idea or equation will not find what you need.
Old Jul 16, 2007 | 10:52 PM
  #80
mudflap1989's Avatar
I guess that I forgot because I thought that "N" in F=uN was the weight of the car. Or more specifically the weight of the car over each individual tire.
