why not turbo diesel
I have a hard time to imagine the sound of the F1 cars
also worth noting is that in 2009, F1 car are going to have to have some kind of power recovery system. this is a majour step and could point to alternative fuels being used!
Chris.
there are a few ideas kicking about at the mo. Xtrac has a very interesting flywheel design. on braking the PRS (power recovery system) flywheel is driven of the engines flywheel thus helping slow the car down. this energy is then storded in the PRS's flywheel untill the exit of the corner. then a second clutch and CVT system will engage to put the flywheels power back to the road.
the other ideas revolve around the tried and test meth of using a gernator to stores the energy in batteries or capacitors.
thanks Chris.
On the subject of Propane, how does it work for a diesel? Do they inject it at the same point in the cycle as you do with diesel? I.E. TDC and later. If so, is it a power producer by way of increasing the combustion ability of the engine by increasing the temperature or helping with fully compusting the mixture?
as for what it does, again this is from memory, but i think it speeds up the combutuion of the diesel. it probably does this by increasing cylinder temps but im not sure. also it is a fuel so it will help push past the limits of the stock injectors.
i will have to dig out the mag when i get back (im away this weekend until monday) and have another read. it was interesting. i will post what it says when i get chance.
anyone else know anything about this????
Chris.
and why is a diesel cr*p for a light weight car??? im currently reading about a guy putting a VW 1.9 diesel into a westfield (like a lotus or caterham 7). get the gearing right and you can gear the torque into power!
Chris.
thanks Chris.
If people are interested in "green" racing, use alcohol!
yes the engines are havier, but ally blocks will be coming out soon and that will make a big differance.
as for the drivetrain, yes it will have to be a little bit havier than say an NA setup, but it would be no worse than a big power turbo setup.
also worth noting that companies like BMW have sequnetial turbo diesels hat offer much better powerband and driveability. also i think honda is useing a sequential setup on its 2.2ltr 4pot diesel!
thanks Chris.
But To Your Guys Point With The Right Tranny And Gearing Even A Diesel Can Be Fast
Hell Ppe Has Their Silverado Running 10.80's So Now Knock 10,000 Lbs Off The Weight Of The Truck With Respect To Putting That Same Motor In A Car And You Really Have Something Verry Fast..
now for a regular street ride like the PMR car, i think its an awesome deal. runs like a stout small block and gets awesome fuel mileage.
One other thought to diesel racing and rev limits as well, the other limiting factor is fuel burn time and driveline weight. To get higher than 5,000 rpm, you have to make up for diesel fuel's slow burn time. This is why Audi limits their race engines to 5-5.5 k. Any more rpm, and you begin to lose efficiency which is diesel's major advantage over gas. Also, not only are the engines heavier, but so are the clutches, transmissions, driveshafts, and differentials/rear axles. They need to be to handle the greater torque. Interesting FYI...when I converted a few Mercedes Benz CLK DTMs to Federal emission specs, I noticed that they were equipped with the rear diffs from the 190 series diesels. They were smaller in size than the standard CLK differential, but much meatier to take the added torque of the supercharged AMG 55 engine. So some diesel parts do make it to the track even in gas powered applications. Bottom line is that there are some races that diesels can prove competitive in (endurance) and some that they'll fail miserably at (sprint or drag). Right tool for the right job, as always.
Cheers!
