Advanced Engineering Tech For the more hardcore LS1TECH residents
home build Cam measuring device ?
Old Jul 2, 2007 | 09:12 AM
jeejee's Avatar
Default home build Cam measuring device ?
anybody that have ever build one ?
any tips or pics ?
thanks. Jeejee
Old Jul 3, 2007 | 11:44 AM
felton316's Avatar
Are you wanting to only measure lobe lift?
Old Jul 3, 2007 | 02:10 PM
jeejee's Avatar
no also duration, and overlap / lobe sep angle
Old Jul 3, 2007 | 04:56 PM
Formulated's Avatar
I've done it before, but with the block and valvetrain in place. I put the degree wheel on the crank, and an indicator on the valve spring retainer. I prefer to do it this way because I get to see the actual valve motion. If you don't have an engine together, then you have to use v-blocks like you have shown. It's just that a fixture for the follower gets a bit cumbersome.
Old Jul 5, 2007 | 03:54 AM
jeejee's Avatar
Ttt...
