proper precedure for break in...multiple items
im in a situation where im gonna have multiple items that are in need of break in and not sure how to go about it.
i have a bran new engine (short block and heads)...bran new Turbo kit...and bran new clutch. how would you go about breakin these items in considering it needs to be tuned? (which i didnt want to beat on it right away b/c of the clutch) should i put a base line tune in and take it easy for a few hundred miles before properly tuning it?? i dont want to cause any problems to one specific item trying to properly set up another if that makes any sence (seating the rings, breakin in the clutch, keeping metal shavings out of the oil, etc etc).
any suggestions would be appreciated as to how i should go about this...thanx.
Youre going to get a wide range of opinions. some people say "take it easy for X miles," othrs will say, "drive it like you will the rest of the time."
Then change the oil and call it good.
JMO
I use 15w/40w Shell Rotella-T oil. This has the extra addatives in it that the oils used to have (do a search if you'd like). I only use this for the first few hundred miles. I heat cycle the motor to full operating temp 3-4 times, varying the RPM's, letting a complete cool down in between. I change the oil the first time after (2) 20 minutes heat cycles. Since the oil is only 11 bucks a gallon, its not all that expensive.
I gradually increase the load on the motor intil about 300-500 miles. After that, its full tilt. I dont switch to synthetic until around 2500 miles. But I guess thats really dependant of the ring material your using.
Clutch:
I tend to go easy on it until I reach a couple hundred miles. But I do typically give it quite a few aggresive releases while breaking it in. I just dont overheat it until its fully broken in. I usually dont get on a new clutch when its cold.
Turbo: I wouldnt worry about it.
JMO
http://www.mototuneusa.com/break_in_secrets.htm
beat the dog **** out of it Clutch can be both eased in and driven hard,I have done both and no diffrence if the flywheel is new or milled
I´m guessing you have cromemoly rings?They don´t need a long time to brake in.
It´s not good to idle much but on inital startup it´s ok to let the motor heat a but up then drive it normally but do not let the turbine boost for the first 100-200 miles but don´t over rev it either 75% of the usable RPM range is pleanty,it´s just about getting the rings seald in
If your computer is not programmed,that is the first thing to do,get the airflow and fuel charts good before trying to brake it in,the rest will follow
As for break in method, its not an exact science. I will say this. I just broke in a 8.3:1 forged piston 4G63 (made for boost). So fairly loose ring gaps on top of the low low compression ratio so that it like regular pump gas and lots of boost. It still had 150PSI on all cylinders despite those factors. I broke it in with light throttle, less than 4000RPM, and lots of varied revs for 500 miles, followed by pretty typical DD duty. An 8.7:1 combo had 170PSi across on the same method. It does not burn oil either.
Id rather do a slow break in and know its fine than beat on it. Plenty of time to beat on it later. Doing it the slow way costs nothing but time.
