Advanced Engineering Tech For the more hardcore LS1TECH residents
How are you guys setting up your timing pointer
Old Jul 24, 2007 | 07:10 PM
Phil99vette's Avatar
7 Second Club
Default How are you guys setting up your timing pointer
I'm using an ATI superdamper with the timing marks already on the outside of the damper. What is the best way to locate the damper to get an accurate position when #1 is @ TDC and your damper is basically @ 0 degrees? Is it easier to just use one of the stick on strips?
Old Jul 24, 2007 | 07:39 PM
LS1curious's Avatar
Use a degree wheel TDC the motor and Use a Sticker.It doesn't hurt though to make a permanant groove or deep physical mark
Old Jul 24, 2007 | 09:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Pic of mine, thank you Speed Inc:
Old Jul 25, 2007 | 08:29 PM
NIIN20's Avatar
Thanks John!
