torque and horsepower at 5250
It made you think, which is good.
I don't think a fusion reactor implies >100% efficiency. If it consumes a megawatt while it is producing 1.02 megawatts, that's about 2% efficient, at least the way I figure it. If the hydrogen fuel is fairly cheap (?), even 2% could make a lot of usable power.
Just my take on it. I'm not a particle physicist, however.
The difference with controlled fusion (either magnetic or inertial confinement) is that it takes a big gob of energy to initiate and contain the fusion reaction, not just a tiny spark. However, whether it takes a match or a blowtorch to light a firecracker, the amount of energy that can be released by that cracker doesn't have much of anything to do with how big the flame was that touched it off. Right now, small controlled fusion firecrackers can only be lit with blowtorches that burn about the same amount of energy as the crackers release. Research into bigger crackers (or whole strings of little ones) and smaller blowtorches should be able to greatly change the energy balance sheet -- and that has nothing to do with greater than 100% energy conversion efficiency.
i was just wondering about this because i saw the historic 1970's era IMSA and CAN-AM car races on the speed channel yesterday, and those big block (500+ cu in) can ams were very impressive- they were in excess of 800hp at lower rpms. i thought those race cars were much more entertaining than the high tech controlled race cars of today- they just don't seem to have any ***** now, just alot of high rpm noise which has the psychological effect of making you think the car is extremely fast (except for Audi's R10 diesel race car).
Torque at the drive wheels accelerates a vehicle. The 10000 rpm engine with half the torque of the 5000 rpm engine (at power peak) would have twice as much gear to achieve the same mph. If driveline losses were the same (or ignored for this quick look), and the shape of the torque curves was similar for the two engines, torque at the wheels would be the same as would horsepower.
An extreme example would be the 900 hp+ V10 F1 engines of a few years ago. The flywheel torque for 900 hp @ 20,000 rpm is, of course, 1/2 the torque of the 900hp @ 10,000 engine and 1/4 that of the 900hp @ 5000. engine.
It appears you hijacked back on topic.
