DCR and head flow
Digging into the port flow and its relationship to performance, i think its time you get a copy of heywood. There are so many things you need to factor in and its best learned by reading... and the fact that i dont feel like typing much either
*edit* I guess if you have a better flowing head reversion of the intake happens at a greater rate? I mean, if it flows better it should flow better in both directions
However what was said about wave dynamics is correct.
Air has mass and therefore it has inertia... it takes time to speed up and slow down. And to put it simply: at your target rpm value, you want to time the IVC to match the point at which air stops flowing through the intake port...
The piston is already on its way back up before air stops flowing into the chamber.. and the higher the speed..the later the IVC point becomes to achieve this. High RPM = late IVC, Low RPM = early IVC.. now you can see why varaible valve timing is helpful (and this is only a small part)
For example: you have your IVC/DCR closing point setup so that its ideal for 5000rpms.. below that you will have reversion and above that you will have restriction (or close before the air is finished flowing)
Characterized by continuous change, activity, or progress
It does change.. and thats why someone assuming that dynamic compression ratio varies only with IVC isn't fully understanding what is going on.
Dynamic Compression ratio is also referred to as "Corrected" compression ratio.
the Word 'Dynamic' may be misleading. Its effectively the cylinder volume at IVC minus cylinder volume at TDC
SCR = Volume at BDC - Volume at TDC
DCR = Volume at IVC - Volume at TDC
In effect, people care far too much about DCR.. its not that important!!! The relationship between SCR and DCR is more important that a single target value for each
Quiz:
2 engines.. Same DCR.. which engine is designed for higher rpms?
Engine 1: SCR 13:1, DCR: 7.5:1
Engine 2: SCR 8.5, DCR 7.5:1
(note, i arbitrarily picked values..)
Also.. bonus, what would you call an engine with a significantly early IVC or significantly late IVC (i.e. what cycle)
more of the same........
I've been against DCR values even being looked at since the begining.. IVC and SCR are the important factors.. DCR means nothing
For example, take an LSI stock engine and throw a big cam in it. The powerband has now shifted to the higher RPM range without touching the intake/exhaust, its purely from cam events.
Matching all of the components for the best power band is exactly what a good engine builder/designer/engineer does...
