Explain wide duration cams?
Jon
I'm pretty sure Jenkins and Garlits didnt
I WANNA KNOW WHY GM USES THESE DARN SPECS NOW ANSWER OLDMAN....
Could this explain the differences in intake/exhaust flow?
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
For reference, overlap on the first cam has -26* overlap... second one has -30*.
Do to current designs and limits of valve sizes and volume of cylinder head exhaust ports, the increase in exhaust duration would be to compensate for this lack of flow compared to the intake flow.
Since engine are limited to certain bore sizes and combustion sizes, you have to split available space for intake and exhaust valves, from an engineering stand point it isn't practical to have the same size exhaust and intake valves because the smaller intake valve would suffer a greater power loss than a smaller exhaust valve.
Also the size of the volume of the port also effects the need for greater exhaust splits, but keep in mind, valve size is very important on flow, adding a few more cc of intake or exhaust volume will not effect power as much as the actual increase in valve size.
In layman's terms, running a larger valve will net you a great gain in power than running a slightly larger port size.
On average the intake valve is about 1.25 times larger than the exhaust valve.
I am not 100% certain so don't jump on my for it, but an average head would flow about 65-70% on the exhaust as compared to the flow of the intake in cfm.
Another reason to have more duration on the exhaust size would be to compensate for increased exhaust flow that is created from nitrous oxide and super charged applications.
Right or wrong, just my .02 cents, and time for beer and super bowl
Old school thinking made less HP, did it less efficiently, and with more emissions.
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
