Advanced Engineering Tech For the more hardcore LS1TECH residents
Offset bores?
Old Mar 13, 2008 | 01:23 PM
Drew04GTO's Avatar
Default Offset bores?
I was reading some stuff the other day about the Honda Insight engine using offset bores to move the connecting rod inline with the piston during peak cylinder pressure. I know it would require a custom one off block and I'm not really interested in trying this out myself just curious to see if its ever been done on anything but this motor. Valvetrain would probably also be beyond wacky, when is GM supposed to come out with that OHC LS motor?
Stolen from InsightCentral.net
"The engine block has a unique, offset cylinder design in which the bore center is offset 14mm from the crank center. Maximum combustion pressure occurs at a point where the connecting rod is straight up and down in the cylinder. In this position there is zero lateral force so friction and piston slap are reduced.
As a result of the offset construction, the combustion pressure is used more efficiently since the rod is near it maximum leverage point with the crankshaft."
Old Mar 14, 2008 | 09:48 PM
Old SStroker's Avatar
Originally Posted by Drew04GTO
...when is GM supposed to come out with that OHC LS motor?...
Not long after the highest ambient temperature in Hades is -1°C. Keep your eye on www.weather.com.
Jon
Old Mar 14, 2008 | 10:14 PM
gun5l1ng3r's Avatar
Jon
At least they are sticking to a proven, durable, design, instead of bending to those stupid car mag authors who seem to think that OHC is the only way to go...
Old Mar 15, 2008 | 01:39 AM
Drew04GTO's Avatar
Agreed, none of the OHC engines can go 200K+ miles without anything but an oil change and plugs. But I'm not debating how proven pushrods are. Is the offset bores thing too far outside of the box? Less piston slap and skirt scuffing as well as a few extra HP seems awsome if you can bring it in with the OEM design.
Old Mar 15, 2008 | 08:24 AM
When GM decided to go with pushrods for the LS series of engines vs. Ford's Modular OHC approach, they committed hundreds of millions, perhaps a billion $ or more by now to the design, development and especially tooling to build the LS pushrod engines for many years. Perhaps it won't run 50 years like the Gen I SBC, but ya' never know.
I have not seen anything that would indicate an LS redesign for OHC. Rather GM has designed, developed and built other OHC engines like the HighValue 3.6L V6. The DI version @ 300+ hp is right in there with the rest of the world's similar engines. However, when bigger NA power or torque is needed, the LS family is avaiable. A 6.0L LS3 version in the G8 is about 1 second quicker in the quarter mile than the similar weight CTS 3.6L DI. The CTS-V is going to get a blown version of the (pushrod) LS engine. I guess we'll see if the 550hp CTS-V competes well with the DOHC entries from the other countries.
FWIW, that's my elaboration of "When Hell freezes over."
Jon
Old Mar 15, 2008 | 10:09 AM
proelky's Avatar
I was searching for rods yesterday and a couple manufacturers offer an offset rod too!
Old Mar 15, 2008 | 11:02 AM
HSV-GTS-300's Avatar
I see the advantage for the power stroke......but wouldn't rod angularity, scuffing,lateral force, slap and friction also be increased (due to the offset) on both of the upstrokes ? No mention of that in the article.
Old Mar 15, 2008 | 11:07 AM
DanO's Avatar
Jon
Yup, just goes to show that a little "engineering" can make any design perform well in its application.
GM decided to take the so called 'old school' approach. Pushrod V-8 with a Supercharger. Just look how far they took that technology.. amazingly high flowing and efficient cylinder heads, used a 75+% efficient supercharger.. and made 550hp... and they certified it for 100,000+ miles.. That deserves some credit in my book. Just think what it took to have a 550hp engine 10-20 years ago.. there was no way it was going to be as fuel efficient or be as durable.
Old Mar 15, 2008 | 12:22 PM
Drew04GTO's Avatar
Good call on that, I didn't even think of how horribly lateral the rod is going to be just after BDC of the up stroke.
Old Mar 15, 2008 | 08:22 PM
XtraCajunSS's Avatar
Yes, but if my thinking is correct, piston speed and loading would be much lower when this occurs.
Shane
Old Mar 15, 2008 | 11:25 PM
2002_Z28_Six_Speed's Avatar
I think the offset argument is BS.
Expansion of the gasses is pushing the piston down evenly so no side loading or scuffing there. When the piston is moving down to fill the cylinder there is little loading on it compared to the power stroke so wear can't be as much even if the rod is making it scuff some due to geometry.
Something doesn't sit right with me. I know I took college classes a long time ago but I remember that even if forces are supposed to be transferred into the walls of the cylinder due to the geometry I think they can't if there is not alot of friction between them.
I would think due to its design and lubrication it acts mostly like a roller instead of heavily scuffing the cylinder walls. Oh well. I am not a mechanical. Just slightly interests me.
I still call the argument BS.
Old Mar 16, 2008 | 08:44 PM
It wouldn't be the first time Honda has designed and built something that had 1 advantage......despite the fact it may be a nightmare to tool up for,build,operate and maintain.
Does anyone remember the oval cylinder and piston NR500/NR750 race bikes ?
Old Mar 16, 2008 | 08:46 PM
Drew04GTO's Avatar
HAHA, yeah, talk about a nightmare.
Old Mar 17, 2008 | 12:00 AM
A. How much for a set of rings on that bad boy.
B. What kind of cylinder head design?! What kind of advantage does it have? I would think with such an open design you have less control over turbluance and airflow... Seems very complex to plan for but interesting.
Old Mar 17, 2008 | 02:13 AM
ThirdGenLS1's Avatar
well just by looking at it i would figure they did it so they could fit more valves per cylinder trying to get a better afr and burn.
Old Mar 17, 2008 | 02:38 AM
chuntington101's Avatar
DAM! never knew thay rad two rods. still 8 valves per cylinder would just take the p!ss lol.
but its ideas like this that move things on. they are not to be laughed at.
Chris.
Old Mar 17, 2008 | 11:51 AM
Eskimo's Avatar
Actually, IIRC, the reasoning for it was a weight penalty (by the sanctioning body) for more cylinders.. They were wanting to run a V8 bike with tiny *** pistons so it would rev to 15k+, but the weight penalty was too much, but they figured if they siamesed the pistons together, viola'! It's just a V-4.
It was also a $60k+ bike back in the early 90's..
I lusted after that bike, even though I would never own one..
Old Mar 17, 2008 | 12:56 PM
Drew04GTO's Avatar
IIRC you're right on this. Here's what confuses the **** out of me though, if its 2 stroke why does it have valve reliefs?
*edit* Nevermind, it was a 4 stroke, was mistaking it for an NSR. The NR500 revved to over 20k in race trim though!
Last edited by Drew04GTO; Mar 18, 2008 at 11:57 AM. Reason: changed that enormous pictAr
Old Mar 18, 2008 | 02:39 AM
how did they keep that thing balanced?? and at those engine speeds!!
Old Mar 18, 2008 | 11:50 AM
Drew04GTO's Avatar
Those engines actually had multi piece crankshafts with splined pieces that would press together. If you notice the rods are single piece and have ball/needle bearings where they ride on the crank. I don't think cylinder phasing is right on that pic with all the valves and stuff, I can't imagine anyone ever getting to ballance correctly like that. Would have atleast thought the other side of the crank would be 180 degrees off.
I can't imagine ballancing that was any worse than Honda's V-5 (yes, a V-5) MotoGP bike that used varrying bores and to ballance the rotating assembly. Its funny how quickly this thread has turned into a "look at all this crazy **** Hondas doing
