Advanced Engineering Tech For the more hardcore LS1TECH residents
Help with comp. ratio
Old Apr 8, 2008 | 04:33 PM
bww3588's Avatar
Default Help with comp. ratio
whats up guys, i think im doing my comp. ratio right, everything im coming out with is giving me 11.22:1 SCR. im using the simple method
total volume
combustion chamber volume
im using stock bore and stroke with GM MLS gaskets. i think they are .051 thats what im using for my calculations and im using Mahle pistons with 4cc valve releifs, TSP PRC 5.3 STG. 2.5 milled to 58cc. someone with some more experience want to help me cause if im right, im going to run a thinner gasket to get it up to 11.5-11.8. not sure if it matters, but im running a MS4 cam
Old Apr 8, 2008 | 06:32 PM
Anti-Vnm's Avatar
Assuming that the Mahle pistons have the same compression height as the stock pistons and still using stock rods (puts it .006 above the deck) and using a GM MLS gasket (I used .053 compressed thickness x 3.97), I got 10.9 CR. Using a Cometic 3.910x .045 gasket, I got 11.17 CR.
Old Apr 8, 2008 | 07:12 PM
405HP_Z06's Avatar
Assumptions:
9.240 deck height
Mahle LS1340898F04 pistons
All other specs from OP
Stock GM 5.7L MLS head gasket:
Cometic 3.910, .040 head gasket:
Old Apr 8, 2008 | 10:53 PM
bww3588's Avatar
sorry, its the stock block, rods and crank. the only thing im changing is the heads, pistons and cam. also all the other neccessary stuff for a heads/cam swap. just let me know if there are any other specs you need.
from the looks of it, im going to have to go with the pistons with the 2cc vavle reliefs, rather than the 4cc. should still have enough room to clear the MS4.
here are the specs from summit racings website
http://store.summitracing.com/partde...4&autoview=sku
any suggestions to get my comp ratio up to 11.5 or so?
Old Apr 8, 2008 | 11:10 PM
405HP_Z06's Avatar
To get 11.5, you would need one of the following (All other variables constant) with a .040, 3.910 head gasket:
1. 2.83 cc valve reliefs
or
2. Mill the heads to 56.83cc's
Old Apr 8, 2008 | 11:13 PM
bww3588's Avatar
http://www.jegs.com/i/Mahle/644/LS13...757295%7C11183
guess it wasent 2cc....this one is 1cc releifs...
Old Apr 8, 2008 | 11:23 PM
405HP_Z06's Avatar
With a .040, 3.910 gasket and 1cc valve reliefs it gets you 11.79. Assuming you have enough PTV clearance.
It's also worth noting these 1cc Mahle's come with 1/16,1/16,3/16 rings instead of 1.5,1.5,3.0mm.
Old Apr 8, 2008 | 11:37 PM
bww3588's Avatar
i called TSP, and they said the 1cc would be plenty. is there any drawbacks or w/e with the different size rings?
Old Apr 8, 2008 | 11:52 PM
405HP_Z06's Avatar
A little more friction, a little heavier, and greater chance of ring flutter at high RPM but not enough to worry about for a street car.
Old Apr 9, 2008 | 12:02 AM
bww3588's Avatar
its going to be a street strip car. proba bly see 7k RPM at the track.......
Old Apr 14, 2008 | 11:40 PM
bww3588's Avatar
well, i got the 1cc pistons, and was wondering, im going to keep the stock MLS gaskets. what will my final comp ratio be?
bww3588's Avatar
i may switch them out to .040 cometics later on down the road.....just not this year.
Old Apr 15, 2008 | 07:42 AM
405HP_Z06's Avatar
This calculation is based on the 5.7L GM MLS dimensions.
Old Apr 15, 2008 | 11:00 AM
bww3588's Avatar
cool, that will be good. i think later in the year i will change out to the .040 cometics....
