Advanced Engineering Tech For the more hardcore LS1TECH residents
Higher Octane Vs Hp Loss
Old May 6, 2008 | 11:12 AM
ls1builderss's Avatar
Default Higher Octane Vs Hp Loss
theoritcally speaking if you have tuned your car for 93 oct. (506rwhp N/A) and run 110 leaded, what is the estimated hp loss if you do not adjust timing for the high octane fuel? trying to settle an arguement
370ci
11:1
ms4
prc stg 1
90/90
Old May 6, 2008 | 12:15 PM
heavy6.0's Avatar
there are a couple factors to take into account here. one is the leaded fuel which your o2 sensors wont like anyways. Higher octane is a "chemical retarder" so your right in mentioning the timing adjustment. but your timing could be off as much as 5-6 degrees and with that compression and cam you could be down 50hp not mention a little a little on the rich side as well. just dont run it is my .02.
Old May 6, 2008 | 03:51 PM
VINCE's Avatar
Shorty Director
Been there and done that. I totally agree. I ran 100 octane in a setup due to not wanting to drive 5 miles to the nearest gas station so I used the fuel I had on hand. Lost 40rwhp and the car was tuned for 12.5 NA it was 10.8 on the dyno that day. This was on a NA setup.
Old May 6, 2008 | 07:56 PM
mrdragster1970's Avatar
6 & 8 Second Club
Don't know the formula. But I do know I test with 3 different octanes whenever I get a new engine. I've had a .1-.2 difference when over octaning an engine. All engines will have a sweet spot, you just have to find it.
