CFM vs. Velocity
I think the peak speed limit is around 614' sec at the min CSA so if you keep south of that you could get some idea of what area/port vol will work in your application.
Energy goes up by the square of the speed e=mc2?. More port speed, more energy at intake closing or any point in between but too fast is worse than too slow and different heads have different limits.
Also remember heads are flowed at 28" h20 (2.07" hg) and a running engine sees much more than this, I think like 406" h20 or so (29.92" hg).
Maybe someone who know more about this could explain it better as I don't know nearly as much about this subject as I would like, its quite complex.
BTW, I don't think an engine can pull 29.92" of Hg from the plenum to the cylinder (the way a flowbench measures), but can pull that much from the plenum to atmospheric upon deceleration. At WOT the plenum is usually .5"-1.5" of Hg (1.5" of Hg is where carbs are flowed at)
I use a "coefficient of discharge" formula. It is basically the airflow divided by the curtain area of the valve. Here is a screen shot of it, I can email it to anyone who wants to use it, just PM me your email address. The most important thing to remember for a street car is the discharge at .300"-.500" is THE KEY, and you DO NOT want a lot of discharge at .100".
You will discover heads with large intake valves have relatively poor discharge through the mid lift but a lot at .100". This is due to the larger a valve gets, the more air it flows at .100" unless you use a steeper seat angle (50-55 versus 45) and the larger it gets the more shrouded it is and the less midlift it has, but will usually show big airflow upstairs, which a street car never sees. Hope this helps.
Let me ask you this Brian.
If you are running a cam with say .650-680 lift in a street car, why wouldn't you want big numbers at .650??
and i second that: why wouldn't you want big numbers at .650"? i've been considering a cam in the mid-230's duration with ~.650" lift for my LSX build. i've seen/heard of a couple C6 Z's hitting 600rwhp with stock bottom ends and stock ported heads/intake.
so after all this info has been brought up, let's delete some variable with constants: we have a 434cid LSX, compstar crank/rods, wiesco pistons, desired SCR of ~11.8:1, hydraulic roller cam custom matched to heads....what heads would *YOU* run to try to hit 600rwhp?
i've looked at ported LS7's, TFS 245's, All Pro 'race prepped' LS2 style heads...to name a few...i really hate making "what do you think" threads, that's why i made this one. i want to be 100% independant when it comes to decission making. i want to become that way by understanding theory and principles of our engines, not by standing on others' shoulders
He gave me some good info and is a really nice guy to talk to about heads. He explained that the biggest head with the most flow isn't going to give you the highest hp and that using the right size head for the motor tailored to the motor, port configuration, shape, valve size, port size made for your motor will make way more power than just just buying a big port head with high cfm numbers, BTW which most companies are full of **** and inflate cfm numbers for sales purposes.
Basically, heads like Ls7's and L92's both have 2 issues that kill velocity.
1. is shrouding over the valve that hinders flow off the seat
2. large intake port kills velocity.
My solution was a smaller cam. Seemed to help a bit. Softer/Lazy lobe seems to allow the head to build velocity vs just opening fast off the seat.
Atleast this is what Rick at Synergy Motorsports or someone else explained to me.
Blah blah blah, you always say stupid **** like this. How about you do something useful for a change and show us your *****.
NWS doesn't matter when you aren't at work. i applaud you for wanting to learn. Very admirable. However there comes a time that you have to decide to let a pro handle the specs or do it yourself.
There are very, very few of us that come out better when we do it.
basically i want the best bang for my bucks without leaving too much power on the table due to lack of topend performance. i'm fine with 600rwhp out of a motor that has the displacement for 750rwhp when built all-out....but i really want that 600....i just want a car that could pull the wheels, run 9's, and get 30mpg. is that so much to ask
Standard location is easy, the only place it really matters. Just before it enters the combustion chamber. I would think you would want to air to accelerate up to the point of entry (the valve) and not slow down before it gets there.
The best advice I've read here is:
You may be your own worst enemy, 2000_SS.
FWIW, I think Jess significantly understated it. The folks who really know how to answer your questions either won't or don't post here. I talk with some of them occasionally and they hang out in other bars.
Jon
To the OP, port velocity is difficult to measure but very easy to compare. Divide flow by port volume. The result is a "dimensionless velocity" in ports / second. If two heads flow the same, but one has a 200 cc port and the other has a 220 cc port, the 200 cc port has higher velocity. Pick the flow for the power you want (1 CFM at 1 port ~ 2 HP) and then select the smallest port that will get you there.
Camming for such is another question entirely.
ok genius, you wanna shed some light on why this is stupid? it makes sense to me. if 2 ports flow the same volume of air in the same amount of time, and one port is smaller, it MUST have more velocity....?
But not necessarily more power. And that is what we all want isn't it??
KInd of hard to brag on velocity numbers..
