Advanced Engineering Tech For the more hardcore LS1TECH residents
aftermarket rods question / modification
Old Jun 10, 2008 | 02:42 AM
jeejee's Avatar
Default aftermarket rods question / modification
what do you guys think , would it be nessesary to install these cuts in the h-beams too ?
I allready installed oil squirters too.
(it's for a non ls1 engine as you might have guessed)
thanks, Jeejee
Old Jun 10, 2008 | 10:17 PM
The Dark Side of Wil's Avatar
What's the application?
AMC 258's and Jeep 4.0's have a small chanel cut into the rod cap which sprays the major thrust side of the bore with oil as the engine turns and helps keep the bores from oblonging.
Old Jun 11, 2008 | 03:20 AM
jeejee's Avatar
its for a *cough* bmw m5 turbo engine
Old Jun 11, 2008 | 05:58 AM
Awake455's Avatar
The folks at BMW aren't idiots when it comes to engines, I'd say it might be a good idea to put that in the new ones as well. Is it on both sides of the rod or just one?
Then again, if you have installed under piston oil squirters when there wasn't any this might be redundant and a bit of a waste of good oil pressure. It would be nice to find a definitive answer as to what BMW's purpose was. In the AMC/Jeep example above, we have an idea of the OEM's intended function of the groove. On the big old Oldsmobile engines Mondello insists that the rods having a groove directly in line with the beam make the difference between the engine living and dying.
Dang, the OEM rods look pretty meaty. I am surprised they need to be upgraded..but looks can sometimes be deceiving. Should be a wicked lil engine.
Old Jun 11, 2008 | 07:09 AM
jeejee's Avatar
the standard rods are pretty strong, they are forged and should be able to withstand about 700-750rwhp, the goal is around that area, but i'd rather be safe then sorry
i'll have to check , but i think the cut is on both sides.
i guess if it wasn't nessesary bmw would not install these grooves
Old Jun 13, 2008 | 06:14 AM
6 / 8 / 10?
It looks pretty obvious to me that these are "informal" piston squirters, although they may have some affect on bore wall lubrication as well. They should be always pointed pretty much at the piston.
If you've installed dedicated piston squirters, then those grooves would be redundant.
Machining them into the new rods just might be detrimental, in terms of fatigue crack propagation. Can you polish or re-shot peen the new rods after you make the cuts?
Old Jun 13, 2008 | 04:49 PM
jeejee's Avatar
no easy possibility to get the rods re-shotpeened and / or polished.
i guess i'll better do without them.
Old Jun 13, 2008 | 08:48 PM
Is this for the 6 cyl, 8 or 10?
Old Jun 14, 2008 | 02:50 AM
jeejee's Avatar
ah okay that was you ment with 6,8,10
it's for the 6, the 3.8 evo (347hp) version
i spoke to a guy wo runs a 2.3 m3 turbo engine which is basically the same just missing 2 cylinders, and he was running a little over 800HP without these cuts in his rods, so i guess with 50% more engine, i'll be fine for about the same amount of power
