Why use a t-stat?
My bottom line is that I know what I have personally experienced... and that is that STREET cars I have owned have performed better with the proper T-stat. The proper T-stat in a properly working cooling system keeps the coolant in the correct operating range. Yes, in the winter you need the T-stat to function and function only when it should. I had a BMW that would prove you wrong if you try to tell me otherwise. T-stat stuck open (effectively NO T-stat) and you couldn't get heat/defrost no matter how long you drove. In winter conditions the coolant simply wouldn't get warm enough.
Remember guys, I am talking about street cars. Other posters may not necessarily be and I'm not speaking for them.
water is one of the best fluid conductors... and the coolant and water wetter you should have mixed in with it are even better conductors of heat. they have plenty of time to collect heat, no matter how fast they are moving through.
and when they are forced through the radiator, they have plenty of time to shed it. period. no matter what speed the coolant is moving... it will spend the same amount of time in the block and radiator, as long as the circulation pattern doesn't change.
a thermo is important so your engine will heat up quicker, and that is all. that's why it changes heat up times for climate control.
Agree 100%, as I mentioned.
I've read several articles & they all say the old story that the water must go through the radiator slowly is a wives tale.
If anyone is so worried about time spent in radiator. The best way is get a cross flow & double the time spent in radiator.
This is one of the fundametals of heat exchangers technology.
So, i think this may be a good way to keep both ends of the argument, just enough restriction to get temps up, but still ample flow to adequately cool the motor. I tood some pics of the finished product to illustrate.
Gary
Why is a 160 tstat's hole smaller than the factory one then?
But, when flow is increased, the coolant makes more passes through the radiator than when flow is slower. The total time spent in the radiator ends up being the same.
Question for those who are ditching the tstat on an lsx style engine...what are you doing with the bypass passage? Are you blocking it off or just letting the coolant find the path of least resistance?
I couldn't even say I know what temp the factory tstat opens at.
But it may just be the manufacturer of the tstat is different... and so they use different amounts of the heat sensitive material (wax most of the time, iirc)
The difference in size is comparable to half dollars and quarters...I was told that the smaller size keeps the water flowing slower absorbing more heat to get rid of more quickly.....
