Advanced Engineering Tech For the more hardcore LS1TECH residents
Valvetrain Damage...
Old Jul 15, 2008 | 11:18 PM
LS1Silverado05's Avatar
Default Valvetrain Damage...
Quick Q and I thought maybe the minds in here would be best to ask.
A friend with a 4.6 mustang recently sent his heads off due to a bent valve..after pulling the heads..you could clearly see impact of valve on piston.....my question is...on a motor with factory internals...and timing chains that show no abnormal slack or wear, how exactly can you have PTV contact?? Do the valvesprings not snap them shut quick enough on an over rev or what?...He wanted expanation and I had none...so Im just trying to help him. Thanks!
Old Jul 16, 2008 | 05:59 AM
Jon5212's Avatar
I would think that from an overrev he probably had valve float long enough for the piston to smack the valve as the valve springs were probably over-whelmed. I'm not familiar with the 4.6 and how close the valves are to the pistons in stock form.
Old Jul 16, 2008 | 11:02 AM
In my mind, thats the only way you could have PTV...but still...Im suprised that could happen on a motor with stock clearances.
Old Jul 21, 2008 | 09:21 AM
Jon5212's Avatar
^^ It happens on stock LS1's too.
Old Sep 3, 2008 | 09:08 PM
dz999's Avatar
Angry
Yes, I've experienced this as well. Piston to valve contact after staying on the rev limiter too long. Definitely valve float will do it.
Old Sep 4, 2008 | 09:50 AM
Old Geezer's Avatar
4.6 have the variable valve timing system in it? If so, did it go south?
Old Sep 11, 2008 | 11:35 PM
Sabre002's Avatar
could be from a missed down shift the rev limiter is not going to stop a motor from over reving that is being pushed by the rest of the drive train.
