all aluminium engine requires smaller radiator ?
and i wouldn't say- aluminum engine require smaller radiator. I would say "get away with using" a smaller radiator.
way hotter than thermostat in summer.
Aluminum heads lessen the temperature difference
between combustion chamber and water jacket. So
theoretically you can run hotter water and make the
same heat-throw with less radiator area and more
delta-T.
But you're still better off with more area and let the
'stat regulate it tightly, so you can tune tightly to
it.
