Hi Swirl Piston Design - Soft Heads - Larry Widmer style
#41
Hey Lance, I think BigCID's negative comments were aimed at me, because I disputed his claims that GM "copied" Ford's cross-bolted main bearings, which of course IS BS. Good to hear your wife is OK, I hope things improve for both of you!
Blowhards like bigCID come and go, YOU keep up the good work! You have paid your dues in the automotive realm.
#42
Hi G, thanks and here is a report of F-1 (MAHLE) with an advancement of my Econo-Plug (2009) testing of a Spark Plug Pre-chamber.
My original concept was formed when we "converted" the KHI 650 Desert Storm (gas) Marine bike to run on Muti-fuel. (Diesel JP-5)
We fitted the MB (Diesel) Mechanical Injection (NUKE Battle Field ready) to the KHI enigne, all new with exception of the Cylinder casting.
Next, I tested/developed the Econo Plug Spark Plug chamber with a LSX-400 engine using my bench dyno.
The test verified the ability of a 18:1 AFR engine to operate WITHOUT Miss-fire, NO NOX, NO CO, and Low HC.
Thus a REPORT of Advanced Engine Design.
Lance
Lance
#44
@ bigCID :
"rebadged" really...!?
sure, there is nothing new under the sun/moon, but "rebadged" specifically implies changing the only badge/nameplate... why spend money on engineering when marketing can do it much cheaper.
