Advanced Engineering Tech For the more hardcore LS1TECH residents
Battle of the Merge Collectors
Old Oct 9, 2008 | 02:32 PM
  #41
SlickVert's Avatar
I also agree that Burns makes some of the nices collectors I have seen. A friend of mine has played around with different collector on a engine dyno and track, every time he has improvements with Burns. If you buy parts form them they will spec out a header to meet your needs.
Bob
Old Oct 9, 2008 | 02:38 PM
  #42
The Alchemist's Avatar
UNDER PRESSURE MOD
Isn't the collector on the ARH, QTP, Kooks all modeled after or similar to the Burns collector? All of those have the 'velocity' spike in them.
Old Oct 9, 2008 | 07:39 PM
  #43
Louis's Avatar
Originally Posted by SlickVert
I believe the primary length is not as important as placement of the correct firing order into the collector, collector type, collector diameter and collector length.
For a N/A car set-up, mid range power can be very important.
Bob
Very correct info! Glad to see it!! A header of that type would bring 5-7k in the racing world, and usually space constraints negate it
Old Oct 16, 2008 | 12:15 PM
  #44
Jeff Smith's Avatar
Here's a Header for ya!
Nice Tri-y headers. Fit Ls1/Ls2 motor on '01 Camaro?
How cost???
Old Oct 16, 2008 | 03:25 PM
  #45
Jeff Smith's Avatar
I found link>
http://s41657.sites80.storefront-hos...x?CategoryID=9
Wegner Motorsport has selling Tri-y headers cost $705ea...Nice..
I emailed to Stan's Tri-Y Headers. He built nice it..
www.stan-headers.com
He replied back:
I am sorry but we don't make a Camaro LS1 header at this time. We can custom build a set on your car in our shop and custom headers usually cost between $2000.00 and $2500.00 installed. We should look at your car to determine if there is anything different that we would have to build in order to make all of your smog equipment in tact.
Thanks
Stan Fuller
Owner
Stan's Headers
Office 253-854-5310
Fax 253-854-8945
Old Jan 29, 2009 | 09:50 AM
  #46
Black Sunshine/ 00SS's Avatar
very good info here.
Old Feb 19, 2009 | 01:43 AM
  #47
SS DNA's Avatar
Good thread!
Old Feb 19, 2009 | 02:32 AM
  #48
superbee_68's Avatar
Heres what I can add, the venturi/choke on the merges work to pull the exhaust gases away from the motor. When the pipe diameter decreases, the velocity of the gases increases, which results in a pressure drop, creating a pseudo vacuum effect. My vote for the best design would be the collector that increases back to full diameter size the smoothest, doesn't just immediately go back to 3 inch or what have you. If you increase diameter to quickly, you will get vortices near the sides which will disrupt flow.
Also, I drew up an h-pipe setup the other day that uses two venturis to maximize the benefit of the pressure drop/scavenging. I want to build it and see now it performs.
Not sure if this is 100% correct for maximum power gains, but it's what I learned when I took fluids.
