No Electrical power.....Please Help
K here is the scoop.
I recently Relocated my battery to the back and everything was good for a little bit. Now I have serious issues. My car has no power at all. However, the fuse box in the engine bay is getting power. I checked every fuse and none are blown.
Here is what happened I hooked up the battery and everything was good, dome lights were on door chime was working, then I went to turn on the head lights and all of a sudden everything went dark. Turn the key to the on position, and nothing no lights nothing. I thought maybe the battery blew up, but I put it in another car and it works just fine.
So I started to check all the fuses in the engine compartment and the passenger compartment, all good. Then I thought maybe the wire from the battery to the engine fuses was bad. So I checked the positive post and sure enough, it is getting power.
So what would cause no power to anything, put the power is still going to the fuse box.
