Writeup On dash Swap
Old Oct 10, 2008 | 09:17 PM
Choppers's Avatar
Default Writeup On dash Swap
Is there any writeups that show how to covert 93-97 dash to a 98 and up dash?
Old Oct 11, 2008 | 06:42 AM
6LITEREATER's Avatar
There is somewhere, I just don't know where. I have done it before and can tell you it is fairly easy though. Everything bolts right in.
Only thing you need write up for is gauge cluster. You need a 1997 Gauge Cluster and you need the plug for it.
You have to de-pin the wires from your factory plug and re-pin to the 1997 style. That is time consuming but if you find the write-up not hard.
Other than that you have to extend some wires for the hatch release and I think that is as complicated as it gets.
I did the swap for 818camaro His name is Steve, shoot him a PM maybe he remembers where the write-up was.
Old Oct 11, 2008 | 11:12 AM
Choppers's Avatar
ok yea. what i am doing is i got a 98 ss camaro that was hit really hard in the rear. Car only had 7*,*** miles on it. We are taking the motor and tranny and all that and putting it in mine. Also we are probably going to swap all the dash so that all the gauges will work. THen after that i might put the front clip on my car to. Alot of work going to be done to it but hopefully it will be worth it.
Old Oct 11, 2008 | 11:23 AM
AZ2ENVY's Avatar
Keep the LT front clip man its way more aggressive and better looking
Old Oct 11, 2008 | 12:21 PM
Why not fix the 98SS with your car (be worth more). Regardless, LT1 front end should be a keeper
Old Oct 11, 2008 | 03:09 PM
Choppers's Avatar
because the rear bumper is at the back of the driver seat.lol. car ran though
Old Oct 11, 2008 | 03:25 PM
Vicinity's Avatar
Lmao.
I guess that means the backseat still has the same amount of space...
Old Oct 11, 2008 | 03:57 PM
FastRidesOnly's Avatar
my 93 z28 and 97 3.8 have different dashes. i think i like the 93 style better. i could swap them before i sell the 97 v6. should i?
Old Oct 11, 2008 | 04:00 PM
Choppers's Avatar
yea but not all the gauges will work correctly once i swap the ls1 into my car and my dash is all cracked and this dash is perfect. we already bought the car so i am going to use all the good parts available to me. my front end has seen its better day so i am gonna use the ss front clip on mine. i love both front ends but the ls1 looks better to me and the lighting on the 93-97's are horrible IMO.
Old Oct 11, 2008 | 09:43 PM
CHELOZ28's Avatar
her you go:http://www.cardomain.com/ride/345879/3
Old Oct 11, 2008 | 09:48 PM
^^Yup, that's the one we used... Good job Chelo
Old Oct 11, 2008 | 10:41 PM
Choppers's Avatar
thanks guys.
