Black car blues
Rinse soap off normally
Do a final rinse with an open end hose, no nozzle. This will promote water to sheet off the car instead of bead up which causes water spots.
Use a leaf blower to blow off any heavy amounts of water and water that gets into the cracks and such.
With a MF Drying towel, wipe off any remaining water.
Remember, The less you physically touch the car the better, You can put noticeable swirls in a black car just from touching it with your fingers.
This is the process I use and my car is always spotless.
After 15-20 minutes max, 85-90% of the water is removed from the cars surface. Then i run a nice microfibre, (waffle weave style) to remove the excess water and DONE.
No water spots, just a smooth streak free shine. I used ALL kinds od chamois, the absorber, a simoniz synthetic chamois, a genuine leather one and whatever else is on the market. The above method is the quickest, most effective and leaves a very clean finish!
