View Poll Results: What Car Care Products Do You Use?
Mothers
15.49%
Meguiers
39.44%
Zaino Bros.
26.76%
Other
35.21%
Multiple Choice Poll. Voters: 71. You may not vote on this poll
What Waxes Do You Use?
Old Oct 28, 2008 | 12:59 PM
  #41
beedo's Avatar
Originally Posted by Mr. Luos
I would more than happily put my process up against anything with Zaino...
Wow, I have a black WS6 as well and I would like to have that kind of dept. I have used tropicare swirl remover and alot of there other products and havent had much luck, no bashing they are great but my application may not have been right. I need something good, to get rid of the dredded fine scratches.
Old Oct 28, 2008 | 01:15 PM
  #42
Mr. Luos's Avatar
Honestly, the right process and the right machine can make most any product look great.
I use a PorterCable for all steps except the waxing.
Menzerna or Prima Swirl for light correction of swirls. 4.5" cutting pad.
Prima Finish to clean up minor hazing of harsher polish. 6" white pad.
Prima Amigo to make the black really have a WOW factor. 6" black pad.
Victoria's red to seal it up.
Old Oct 28, 2008 | 02:47 PM
  #43
beedo's Avatar
Where are you getting your pads from, I have been using the ones I got from tropicare, I am using the meguiars mirror glaze line "there professional" compunds and have had good luck but I cant get that mirror perfect paint in the sun light, looks bad *** in the garage when im done but shows the defect in the sun.
Old Oct 28, 2008 | 03:01 PM
  #44
Mr. Luos's Avatar
Lake Country pads.
EDIT:
And I should mention that the polish used to remove swirls....needs to be worked in slowly. It is time consuming.
Old Oct 28, 2008 | 03:37 PM
  #45
WS6_00's Avatar
Lake Country pads.
EDIT:
na no kidding, you have to be patient or you're never going to see the results you want.
I use-
pinnacle sigII
P21S
Old Oct 28, 2008 | 06:38 PM
  #46
Gipraw's Avatar
As long as you are using good, quality products, the process and technique is more important than the product.
turtle wax and nufinish are NOT good products.
Old Oct 29, 2008 | 04:59 AM
  #47
infinite_one's Avatar
i voted other.....you all mean to tell me nobody uses liquid glass? wow.....missing out big time if you havnt tried it
Old Oct 29, 2008 | 04:22 PM
  #48
PedroDePackas's Avatar
I guess I'm other. Right now my stash includes Poorboy Natty's Blue, Finish Kare's 1000P and Pink Wax and Prima Epic, which I believe is what is currently on the car.
Old Oct 30, 2008 | 02:32 AM
  #49
unSStoppable's Avatar
i started zymol but have turned into a megs guy
Old Oct 30, 2008 | 05:51 PM
  #50
DevilDougWS6's Avatar
ive used everything, so far zymol has produced the BEST results for just hand waxing without pc or buffer. another product i used is called liquid lustre which can only be found online. which worked really well.
